Tom's Hardware > Forum > Graphic & Displays > ATI > Will these adapaters work for Eyefinity?
Forum Graphic & Displays : ATI - Will these adapaters work for Eyefinity?
Strongly considering getting two more monitors to take advantage of HD 5870 Eyefinity.
Got a question about adapters, etc.
Here is the monitor type: http://www.newegg.com/Product/..._ [...] -_-Product
Both monitors inlcude VGA cables, but I need DVI. From what I've seen, DVI to VGA adapters are considerably cheaper than DVI cables.
I have two DVI outputs on the HD 5870. I already have one DVI to VGA adapter that came with my motherboard, haven't had any issues with using it so far.
I have to buy an active DisplayPort to DVI adapter for Eyefinity: http://accessories.us.dell.com...d [...] u=330-5521
Can I plug a DVI to VGA adapter onto that without issue?
I found these super cheap, which makes me slightly suspicious, adapters on eBay. Do they seem like they would work?
http://cgi.ebay.com/DVI-DVI-D-..._ [...] 2a0216c757
Also, is there any performance difference between DVI, HDMI, VGA, etc.?
Thanks! Hopefully all this makes sense...
Sponsored Links
HibyPrime wrote :
none of the links work
For some reason, my links tend to not work on these forums. I copy 'em straight from the browser and paste 'em into the thread...?
Anyhow,
the monitor: LG W2753V-PF 27" look it up on NewEgg.com
the active adapter: R478G look it up on Dell.com
the DVI to VGA adapter: keywords, "DVI to VGA adapter" on eBay. There are tons of them that are in the $5 range, which kinda' makes me wonder about quality...
Thanks!
Reply to ITSANSS
Im not sure that adapter will work with a DVI to VGA convertor. The spec doesnt say if its DVI-D or DVI-I connector on the end?
If its DVI-D, which I think it may well be, then the DVI to VGA adapter wont even fit on it.
Reply to tricky_uk
Why scew up a perfectly good digital signal from DVI, which you are spending money to produce, only to ram it through a crappy analog VGA lowest common denominator POS? Between the monitors, the graphics card, and the active converter, your into this for the better part of $2000 bucks already. Just spend the extra 20 and get some DVI cables, and avoid degrading your signal or possibly causing eyefinity problems by ramming a good signal through a lousy analog connection like VGA. These are nice monitors, and a nice graphics card. Shell out for the correct cables, bro.
Reply to spider83
the only poblm i can see is that can vga handle the output of 1920x1080?
i do agree that the best way would be to just buy DVI-D cables and not have to worry about the adapters.
i got mine from amazon
http://www.amazon.com/s/ref=nb_ss? [...] vi+d+cable
Reply to paperfox
There are 1161 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
