Tom's Hardware > Forum > Homebuilt Systems > New System Build > Do i need a sertain kind of ram and power supply?
Forum Homebuilt Systems : New System Build - Do i need a sertain kind of ram and power supply?
i am going to get a XFX nForce 750i SLI Motherboard can i just buy any type of ddr2 ram an psu or is there sertain ones i need to get?
Sponsored Links
Any standard DDR2 ram will work, however there are some which will provide you better performance at a good price, lower latency is better, like CL5 1066MHz ram like this stuff.
http://www.newegg.com/Product/Prod [...] 6820231166
For the power supply, dont just buy the cheapest one you find, it will cost you more in the long run. What processor and graphics card will you be running in this system? Those will determine your power needs.
Message edited by hunter315 on 10-13-2009 at 12:12:54 AM
Reply to hunter315
i would only reccomend that motherboard if you are actually going to use SLI, otherwise go to an Intel chipset based motherboard for the best results
------------------------------ Q6600@3510/1560 + TT BigTyphoon+Mod
8gb Kingston 800mhz
Gigabyte EP35-DS3P
XFX 8800GT/512
Reply to apache_lives
There are 1254 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
