Tom's Hardware > Forum > Homebuilt Systems > New System Build > Need advice on motherboard,case, and ram $150
Forum Homebuilt Systems : New System Build - Need advice on motherboard,case, and ram $150
I need mobo, case, and ram to update an old an old hp a500n- http://h10025.www1.hp.com/ewfrf/wc [...] =c00070262
i already have cpu- http://www.newegg.com/Product/Prod [...] 6819103772
225wat -power supply that came with comp- good enough for my new build?
Message edited by nun on 10-13-2009 at 02:11:34 AM
Sponsored Links
Its a bit hard to give good advice without more information .
Whats the budget?
What do you use the computer for?
And you might get away with the psu , but definitely wont if you have a graphics card to run as well
Reply to Outlander_04
budget is in title $150, and i will use the computer for a htpc, internet browsing, and maybe a second gaming rig later when i get a new power supply.
Reply to nun
COOLER MASTER Gladiator 600 RC-600-KKN1-GP $50 w/free shipping
http://www.newegg.com/Product/Prod [...] 6811119206
GIGABYTE GA-MA78LM-S2 AM3/AM2+/AM2 AMD 760G Micro ATX $65
http://www.newegg.com/Product/Prod [...] 6813128407
Micro atx but fits the case , good quality and unless you need to install 5 expansion cards its good value
mushkin 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 $40
http://www.newegg.com/Product/Prod [...] 6820146764
A shade over budget but its good enough quality , and will work well with your processor
The mb even has onboard gfx and that will keep power demand low and hopefully let you run it on your psu till you can upgrade psu and gfx
hey thanks a lot I will look through those links
any other suggestions
Reply to nun
Outlander_04 that mb doesnt have many reviews and no hdmi out, plus olny 2 slot of ram would like 4 if possible but not nessary
Here is what i've chose so far:
case-HEC 6C28BB8S Black Steel ATX Mid Tower Computer Case
http://www.newegg.com/Product/Prod [...] 6811121001 this seems like a prett good basic case for my needs
thermal paste- http://www.newegg.com/Product/Prod [...] 6835200052 picked bc the free shipping
ram- http://www.newegg.com/Product/Prod [...] 6820134488 picked bc free shipping again, and good brand i geuss
Does everything look good?
Still need a mobo for around $50-60 maybe with hdmi out and 4 slots for ram possibly, also free shipping if possible
Any suggestions?
Message edited by nun on 10-14-2009 at 03:55:44 AM
Reply to nun
The RAM you picked has much looser timings . The spec says it has CAS timing of 6 . The one I listed has 4-4-4-12 , which means it does in 4 MHz what your selection takes 6 Mhz to do . Even though they are both rated at 800 MHz your selection is WAAAAY slower .
Shipping on RAM wont cost much . Its small and light .
If your processor came with a heatsink and its all new then you wont need thermal paste . There will already be a patch of paste painted on the heatsink.
ASRock A780GMH/128M AM2+/AM3 AMD 780G HDMI Micro ATX $60 after MIR
http://www.newegg.com/Product/Prod [...] 6813157154
Asrock is a good budget brand , and it has the same good onboard graphics
If you are planning on gaming your case wont do. It has one small fan in the back and wont shift enough air to cool everything . The coolermaster has two large fans in the top and back .
But you are right the hec will do for basic needs .
Message edited by Outlander_04 on 10-14-2009 at 06:06:36 AM
hey thanks that mb looks great and i ll go with the ram you posted earlier, but the processor isn't brand new it coming from my main build that i just upgraded and it needs a new layer i believe.
Reply to nun
There are 1264 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
