Built the rig back in late 07. I recently revamped the inside of my case with new fans and did some cleanup with my cords. For whatever reason, my computer is freezing when I play Team Fortress 2. It happens at random, and only while i play the game. I can play any other game on my computer for hours and hours without a hickup.. Need some help... Ive already done a disc defrag, got the latest and greatest updates for my game and for windows.
Specs:
Windows XP 32-bit SP2
AMD Athlon 64 X2 6000+ Windsor 3.0GHz 2 x 1MB L2 Cache Socket AM2 125W Dual-Core Processor
Seagate Barracuda 7200.10 ST3250410AS 250GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive
ASUS M2N-SLI Deluxe AM2 NVIDIA nForce 570 SLI MCP ATX AMD Motherboard - Replaced within 6 months, (lan ports stoped working, sent me a new board)
GECUBE GC-XHD3850PG3-E3R Radeon HD 3850 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready CrossFireX
CORSAIR XMS2 4GB (4 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400)
KINGWIN Revolution RVT-9225 92mm H.D.T. CPU Cooler
RAIDMAX AURORA 2 RX-600F 600W ATX12V V2.2 / EPS12V SLI Ready CrossFire Ready LED Power Supply
APEVIA X-CRUISER-BK Black Steel ATX Mid Tower Computer Case
2x APEVIA CF4SL-UBL-LED 80mm Blue LED Case Fan
2x Rosewill RFA-80-BL 80mm 4 Blue LEDs LED Case Fan
Thermaltake A1926 120mm Blue LED Case Fan
Previously i had the 2 apevia fans, along with another offbrand 80 mm side fan, and 2 80 mm thermaltake intake fans. 2 of my 5 fans were equiped with leds. Now all 5 of them have leds. I dont see this causing the issue but maybe it is??
Any guesses or suggestions why this could be happening?
My temps on everything are great, the case has very good airflow... CPU and MOBO never climb above 100 even after hours of gaming... Graphics Card stays at ~60C after hours of gaming while under full load, ive actualy never seen it go above 61C before.
Can this be a power issue?
Im not sure how much power my system is actualy using but i dont think i am pushing to its limits.. I built the system in late 07 so a 600w PSU was all sorts of big and fancy... I figured i would never even use that much power but maybe i am and then some??? Any help would be appreciated..
Specs:
