Hi i need help with overclocking an HIS Radeon HD 6850 and i sant to use CCC just to be safer. What kind of clocks are stable for this and thanks in advance
P.S i do not want to use msi afterburner or trixxx
CCC has a section, called AMD Overdrive that will Auto-Tune your card to the maximum stable settings. It may take a awhile to complete the tuning. Save the result/settings as a new profile.
It only auto tunes the cpu not the gpu for the gpu i need to change the gpu clock settings = max is 850mhz and the memory clock setting =1200mhz im not sure what to change it to?
if you do not get in trouble go ahead ... and hope without the addition of voltage, but must be considered also by increasing the temperature of the fan speed
What do u mean if i dont get troubled? Also hope without the addition of voltage but in ccc it dsnt let me change voltage would it increase if i chng the clock settings?
