Tom's Hardware > Forum > Homebuilt Systems > New System Build > Need Help on Parts! Machine for FSX!
Forum Homebuilt Systems : New System Build - Need Help on Parts! Machine for FSX!
Hi,
APPROXIMATE PURCHASE DATE: Not for a while, whenever I get to it BUDGET RANGE: $700 with no OS, around $800 with
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: Everyday tasks, Flight Simulator X with very good performance
PARTS NOT REQUIRED: Monitor, Mouse, Keyboard, Speakers
PREFERRED WEBSITE(S) FOR PARTS: newegg.com please
PARTS PREFERENCES: AMD usually has more bang to the buck, so AMD please
OVERCLOCKING: No
MONITOR RESOLUTION: 1440 x 900
ADDITIONAL COMMENTS: As long as it runs FSX decently.
As of right now, this is just a basic mockup:
CPU: AMD Athlon II X4 620 2.6GHz ($100)
http://www.newegg.com/Product/Prod [...] 6819103706
Motherboard: ASUS M4A785TD-V EVO AM3 ($100)
http://www.newegg.com/Product/Prod [...] 6813131398
Memory: G.SKILL Ripjaws Series 4GB (2x2GB) ($90)
http://www.newegg.com/Product/Prod [...] 6820231276
HDD(s): Corsair Extreme Series 32GB SSD ($150)
http://www.newegg.com/Product/Prod [...] 6820233089
Western Digital Blue 320GB HDD ($50)
http://www.newegg.com/Product/Prod [...] 6822136074
Case: Cooler Master Case ($40)
No Link, just any one of their cheap cases
PSU: OCZ ModXStream Pro 500W ($60)
http://www.newegg.com/Product/Prod [...] 6817341016
ODD: LITE-ON DVD Burner/Reader ($30)
No Link, whatever is in stock or looks good
GPU: XFX ATi Radeon 4770 512MB ($110)
http://www.newegg.com/Product/Prod [...] 6814150369
Total Price: ($700)
Hoping I can fit both Windows and FSX on the 32GB SSD, and maybe the windows page files. It will be very close.
Ideas anyone? Thanks!
Message edited by lauxenburg on 10-14-2009 at 01:03:39 AM
Sponsored Links
Well I was doing a little more research because I saw that the ATi Radeon 5770 and 5750 were released. The 5770 is about $150-180 and a helluva improve over the 4770. And now, I am thinking maybe get rid of the SSD because I saw many discussions that ended with "no SSDs really do not make a great performance improvement in FSX", so maybe....save a couple of bucks and do not get the SSD. Get the Radeon HD5770 for about $175.
I like XFX. Have one older card from them, but I am a satisfied customer. =)
XFX ATi Radeon HD5770 1GB PCIe 2.0 x16
Not sure.
Reply to lauxenburg
$5 more for a faster larger drive
http://www.newegg.com/Product/Prod [...] F3%20500GB
The 4770 will perform well on that resolution so its a good choice. The SSD wont provide any improvement in gaming perform so i would suggest dropping that in favor of more processing power. If you can fit this combo in FSX will appreciate it as it can run up to 256 threads, not do able on todays machines but the 4 extra ones from hyperthreading will help it run smoother.
http://www.newegg.com/Product/Comb [...] mbo.273248
Reply to hunter315
I agree that the SSD won't improve in game performance. AMD really does have good bang for the buck.
But if you can pump up the bang without breaking the bank... thats good too.
Keeping your budget goals in mind:
Intel Core i5-750 Lynnfield 2.66GHz CPU combo deal $440
GIGABYTE GA-P55M-UD2 Intel P55 Micro ATX Motherboard
XFX GTS 250 1GB Video Card
Plus the $270 worth of RAM/HDD/Case/DVD/PSU you listed (without the SSD) brings you in just over $700.
Any other games you play besides FSX? Maybe Lock On; Modern Air Combat?
Reply to WR2
Thanks alot guys.
WR2, I am really digging that combo deal. and hunter's yours is just as great. The CPU + Motherboard is probably a lot better from Hunter, but I may not need that much.
I don't think I will be able to make a purchase that quickly, but if I see a very similar combo later, I will defintley dive at it. Newegg has some great deals. Who knows I might be able to slash at it now.
Well, FSX isn't the only thing I play. I do enjoy a good racer or two, say Need For Speed Shift or something similar.
Thanks.
Message quoted 1 times
Message edited by lauxenburg on 10-14-2009 at 03:42:04 AM
Reply to lauxenburg
I thought that might be the case. Thats an even better reason to upgrade a bit with the i5 750 / GTS 250.
The Athlon II X4 620 is a fine entry level quad core but the i5 750 is a pretty good step up. And the i7 860 is a real powerhouse.
Let us know if you want to see some benchmarks.
Reply to WR2
I would go with the WD Black 640GB. It is newer and should have better performance. Also its only 15 dollar more
------------------------------ i7 920 | Scythe Mugen Cooler | Asus P6T | OCZ Gold 6gb | Asus Radeon HD4850 TOP @ 680Mhz | Western Digital Caviar Black 1TB | Corsair 650w | Cooler Master CM-690 | Asus 21.5" (2) | Windows 7 x64
Reply to jsrudd
Wow...I was thinking about that i5, and my budget is just getting wrecked. It really needs to be under $800 with an OS, so essentially $700 in hardware.
This is going to seem anti what everyone has been saying, so don't get mad please:
CPU: AMD Phenom II X2 545 3.0Ghz Dual Core
Motherboard: ASUS M4A785TD-V EVO AM3 Motherboard
RAM: 4GB G.Skill Ripjaws DDR3 1333
Graphics: XFX ATi Radeon HD5750
PSU: Corsair 450W
HDD: Western Digital Black 500GB 32MB Cache
ODD: Lite-On DVD Burner
Case: Cooler Master Elite 330
OS: Windows 7 Home 64-bit
Total Price: ~$795.
Ideas. Sorry for sort of throwing ideas out the window here. But, my budget must be abided by.
Reply to lauxenburg
But, I do not want to settle for anything but the best...even if its isn't that Hi-end.
Reply to lauxenburg
There are 935 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 04:06 xyz001 won the Sophmore badge
  • 01:00 scione won the Freshman badge
  • 01:32 aford10 won the Home Brew badge
  • 01:00 Kevinator won the Uniformed badge
  • 01:00 adis won the Uniformed badge
  • 01:00 dabell won the Uniformed badge
  • 01:00 zebo56 won the Uniformed badge
  • 01:00 drkkmittal won the Uniformed badge
  • 01:00 jakesvdyk won the Uniformed badge
  • 01:00 artistjane won the Uniformed badge
