danirockdude_99
36
Hello i have 2 problem
the firsproblem is (iposted athread about it - http://www.tomshardware.com/forum/272684-30-onboard-video-card-disabling)
and the secont one as i said in the first post ibought anew video card - zotac Geforce 8400GS (512mb 64bit DDR 2) and the installation cd that contains the driver allways says whene i try to install it "No Drivers Fond For Your Hadware" what should i do?
The drivers are probably really old on that CD the 8400gs is an old gpu. Are you using windows xp, Vista, or Win 7. I you are useing vista or win 7 the installer on the disk is probably incompatible with your operating system.
