Can you post a pic of the damage you are speaking about on the CPU block? Blocks don't really get damaged unless you are running mixed metals or actually do physical damage during install or while handling. I'm going to maintain my stance on the CPU block that it can be cleaned and work just fine. In fact, the block doesn't have to be cleaned- oxidation happens naturally and doesn't impact performance, only looks.
Quote:
2) I've already exhausted my means in refurbishing the block, it would need to be cut/flattened in order to remove the extent of damage done to it.
Do you mean lapping? Otherwise, I'm not sure exactly what kind of damage you are looking at here, but it's very likely is only cosmetic.
Quote:
3) *JUST* another radiator, are you kidding? first of all, the limitations of my case are ONE 200mm radiator and ONE 240mm radiator; that's it. I plan on purchasing TWO new radiators, one 240mm for the top and one 200mm for the front. Also, a thick 360 radiator? I'd love to, but where on earth would I put it?! It seems that the 240mm/200mm setup would be best, if only viable option.
No, I'm not kidding. At all. One single bit. You aren't listening to what I'm saying here. If you want to buy a bunch of watercooling gear to replace what you have, that's fine, but you mentioned wanting to drop the overall budget...so please slow down and pay attention.
KEEP the RS240 you have (there isn't a reason to get rid of it unless you just want to buy something else) and then JUST ADD THE 200mm rad. Again, the 360 would be an alternative radiator than you had planned...so you must simply be skimming my recommendations. Again, slow down and take in what is being suggested.
The X20 pump isn't the most fantastic, but it isn't all that bad, either. There are a lot of people that run a setup like this with an expansion of a Rasa kit. Plus, the pump you linked really isn't that great of a replacement, so you are getting poor information on the Rasa pump being that bad, and you are using poor knowledge to choose a poor pump for replacement.
Quote:
5) You're just reiterating your second point; I need a new block, it is badly damaged. It lacks the cooling properties I come to expect in my base rig...
I am going to reiterate my second point again, to make yet another point. The Rasa block is very good on that chip. Please post pics of the damage you are speaking to so we can determine what it is and possible solutions. By switching CPU blocks you aren't going to see substantial cooling differences. Oxidation of a block IS NOT DAMAGE. Oxidation does not cause poor performance.
What is the performance difference you believe you are seeing due to oxidation? Please post ambient temps, idle and load temps.
