The thread name pretty much says it all, save the specifics.
I am running a Pentium D 840 on a d945gpm mobo.
I had a PSU failure, and installed a new PSU.
Now, when I enter hardware monitoring in the BIOS, all fields show "0000"; voltages, temps, and fan speeds.
I did do a BIOS reset using the jumper on the mobo before the first boot with the new psu, if that is even relevant.
The rig seems to be running fine, but I'm worried about burning out my CPU if it gets too hot and is unable to regulate its speed or shut itself off.
My BIOS are the most current version available.
Any help would be greatly appreciated
