ErikEngle :
I just rehooked up my old power supply and tried it with both cards, and I cannot get either of them to work as well. I must have moved something or accidently knocked a wire or something loose?
Most likely. Much less likely, but still possible, is that something else failed during the upgrade process.
It sounds like you replaced both parts at the same time. Mistake. You should have replaced each part separately starting with the PSU and tested after each step. Hindsight, right?
First thing now is to get the original system working. Our standard checklist and troubleshooting thread:
http://www.tomshardware.com/forum/261145-31-read-posting-boot-problems
Try to verify (as well as you can) that the PSU works. If you have a multimeter, you can do a rough checkout of a PSU using the "paper clip trick". You plug the bare PSU into the wall. Insert a paper clip into the green wire pin and one of the black wire pins beside it momentarily - "momentarily" being defined as less that one second. That's how the case power switch works. It applies a ground to the green wire. Turn on the PSU and the fan should spin up. If it doesn't, the PSU is dead.
If you have a multimeter, you can check all the outputs. Yellow wires should be 12 volts, red 5 volts, orange 3.3 volts, blue wire -12 volts, purple wire is the always on 5 volt standby line. The tolerances should be +/- 5%. If not, the PSU is bad.
The gray wire is really important. It sends a control signal called something like "PowerOK" from the PSU to the motherboard. It should go from 0 volts to about 5 volts within a half second of pressing the case power switch.
If you do not have this signal, your computer will not boot.
Unfortunately (yes, there's a "gotcha"), passing all the above does not mean that the PSU is good. It's not being tested under any kind of load. But if the fan
doesn't turn on, the PSU is most likely dead.
On to the real troubleshooting ...
Disconnect
everything from the motherboard except the CPU and HSF, the two power cables going to the motherboard, and the case power switch. Boot. You should hear a series of long single beeps indicating missing memory. Silence here indicates, in probable order, a bad PSU, motherboard, or CPU - or a bad installation where something is shorting and
shutting down the PSU.
If you get the long beeps, add a stick of RAM. Boot. The beep pattern should change to one long and two or three short beeps. Silence indicates that the RAM is shorting out the PSU (very rare). Long single beeps indicates that the BIOS does not recognize the presence of the RAM.
If you get the one long and two or three short beeps, test the rest of the RAM. If good, install the video card and any needed power cables and plug in the monitor. If the video card is good, the system should successfully POST (one short beep, usually) and you will see the boot screen and messages.
Note - an inadequate PSU will cause a failure here or any step later.
Note - you do not need drives or a keyboard to successfully POST (generally a single short beep).
Note - the beep patterns I mentioned seem to be the most common. Those are what I get with my eVGA 680i motherboard, my three Intel Gigabyte boards, and my old AMD AOpen board. Other board may be different.
If you successfully POST, start plugging in the rest of the components, one at a time.
