Solved
CPU Fan Speed
Hello all,
Today I put together my first PC/HTPC and everything went great except for ONE thing. The CPU fan is ridiculously LOUD. Everything else in my system is very quiet. I think the fan is just spinning at full speed all the time regardless of CPU load.. Is there anything I'm doing wrong? What can I do to fix this?
I also uploaded a video to youtube: http://www.youtube.com/watch?v=e3Tt4SSAMBg
Thanks in advance,
Arman
Case: Cooler Master Gladiator 600
PSU: CORSAIR CMPSU-400CX 400W
Motherboard: Asus M4A785TD
CPU: AMD Athlon II X4 620
CPU Fan: XIGMATEK nepartak - s983 92mm HYPRO bearing
RAM: 4GB (2x2GB) G.SKILL Ripjaws Series DDR3 1333 (PC3 10666)
HDD: Seagate Barracuda 7200.12 1TB
Optical: LG CH08LS10 Blu-ray Combo
OS: Windows 7 64bit
2 answers Last reply Best Answer
More about speed
  1. Best answer
    On an ASUS mobo u have some unique ASUS features like EPU engine and Q-fan. EPU helps to save some energy wile u don,t need much power,is very easy to use. Q-fan is like a rheobus, but is a software that help to regulate the fan speed on a system, based on temperatures. If u don't have these installed yet go to the ASUS web site support, specially for Win 7 support . U may use also the AMD Cool&Quiet feature to get the same results. U will find these on "utilities" section. I think u can access the Q-fan utility from the BIOS, or using PC ProbeII as a program in Windows.
  2. All features in the last post must first be enabled in bios. So, check your motherboard manual for these features.
CPUs Components
