Hey guys I just can't seem to figure this out for myself so I figured I'd check and see if I could get some answers on here...hopefully HOW to get this to work or at least find out whether or not it should work.
Anyway, first off my specs:
Motherboard: EVGA 780i
GPUs: nVidia 9800 GTX/9800 GTX+
nVidia 9800 GTX+
nVidia driver version: 191.70
So, I'll go through what I've tried and hopefully someone here knows what I need to do (if I can at all).
I installed the two cards in GPU slot 1 and GPU slot 3 on the motherboard and applied the SLI bridge on the connectors closest to the end of the card. I then closed up my case and plugged my cables back in. Now, I DO use dual monitors and at the moment the system currently displays both monitors exactly as before and my dual monitor setup works fine with both monitors plugged into the top card...if there are any changes that are needed there, please advise. I have also installed the SLI Enhancement Patch and the SLI Profile Update.
After I did this, I went into the nVidia control panel to enable SLI and could not find the SLI setting area...which is still the case. Even in the "Antialiasing Setting" spot in the 3D Settings area doesn't have any SLI options.
So far, I have tried disabling one card in device manager and rebooting and re-enabling with no luck...I have updated my motherboard drivers to the latest...I have even tried reinstalling the video card drivers with both cards plugged in. I don't understand why I can't seem to get the right settings options in the control panel when it clearly reads that there are two cards there. All the settings I can get it to show are what you see in the last picture.
Anyway, please help! Where do I go or what do I do to get my SLI running?? If any further information is needed please ask and I will provide it. Thank you in advance.
nVidia 9800 GTX+
