Please Help, Stuck At Hp Screen
Motherboard Master
I would say the hardrive is the likely problem. Disconnect it and the optical drives and see if it gets past the post screen. Then check all the cable connections. Some of the older sata cables come loose fairly easily. Any memory failure would show up at the post, so I doubt it is a concern. Any changes to your system lately?
Related ressources
Ask the community
