Solved
Problem with x-530 5.1 logitech speakers
  • Sound Cards
  • Speakers
  • Logitech
  • Components
Last response: in Components
December 31, 2009 6:18:41 PM
alright the problem basically is that when i play a game, watch youtube videos, basically everything the 2 side/rear speakers dont play anything, the center, 2 fronts and subs work fine. but when i test the speakers in control panel they work fine, they also work if i plug them specifically into an ipod. is the problem my sound card, im pretty sure its not a 5.1 in fact i don't even know what its called
More about : problem 530 logitech speakers
Best solution
January 1, 2010 12:04:42 AM
If you have 5.1 on your board, take out the expansion card and install the drivers from the board's CD, and plug-in the green, black, and orange jacks.
If you don't, and your sound card is not 5.1/7.1, the x-530 won't work properly - get a 5.1 sound card and install its drivers and control software.
January 6, 2010 5:36:56 AM
if you have realtek hd integrated audio there is an option in the sound manager... i cant remember but its just a box and you tick it and you should have sound through all of your speakers. if i remember there is a little description and its not hard to find.
m
l
April 4, 2010 12:56:36 AM
Best answer selected by xxvousxx.
m
l
April 4, 2010 1:16:53 AM
Its called Speaker fill.
m
l
April 4, 2010 7:10:01 AM
Back from the dead.
m
l
April 4, 2010 7:12:57 AM
LOL I didnt even look at the original post date OP just picked best answer yesterday thou.
m
l
April 4, 2010 7:13:48 AM
So its not like I dug it up from the dead.
m
l
