Power supply up or down?
  • Power Supplies
  • Cases
  • Antec
  • Components
Last response: in Components
December 31, 2009 11:45:31 PM
I have purchased the Antec TP-650 power supply and have been a little confused about its orientation in my Antec Nine Hundred Two case. This is my first build, go figure.
http://www.newegg.ca/Product/Product.aspx?Item=N82E1681...
There is only a single intake fan which, if bottom mounted in the proper position, faces down on the metal of the case. Is this meant to be a top mount PSU? I can't imagine it'd be normal to intake air where there's none to be had, but let me know if my paranoia isn't merited.
More about : power supply
a b ) Power supply
December 31, 2009 11:55:24 PM
If you don't want to cut a hole in the bottom of the case to supply fresh air to the PSU, mount it fan-side up. It'll work.
December 31, 2009 11:58:55 PM
Any known problems with taking already heated air?
a c 144 ) Power supply
January 1, 2010 6:36:09 AM
The Antec 900 & 902 cases have two sets of mounting holes.
You would have the same problems with already heated air from inside the case if your case had a top mounted PSU. In other words, "No."
