Hi all, I am building this new system. I think I have it pretty good, but if you have any opinions or better options please let me know.
I am replacing my old Dell 8250, 3.06 HT, 1.5GB RAMBUS 1066, WD 500GB, ATI HD 3850 AGP with this:
Gigabyte GA-P55-UD5
Intel Core i7 860
OCZ3P1333LV4GK 4GB Kit
HD 5770 Crossfire
Creative Sound Blaster X-Fi XtremeGamer
WD Caviar Black 1TB
LG GH22NP20
Corsair CMPSU-650TX
Antec Three Hundred
Logitech Z-4
I was not sure about the video card, but I read that 2 x 5770 beats any cards out there for the price. I did not go with X58 I7-920 because it is slower to play games.
Get the I5 750, a cheaper motherboard such as the Asus P7P55D Pro and dump the soundcard since onboard sound should be good enough. With the money saved, upgrade the GPU to a 5850 and then bump up the PSU to the 750W version. This would make it possible to add a second 5850 and run them in crossfire when you need more graphics power in the future.
So this would be a better and faster machine (with a $1500 in mind):
Gigabyte GA-P55-UD4P
Intel Core i7 750
HD 5850 Crossfire
SAMSUNG Spinpoint F1 HD753LJ 750GB (The F3 is not available)
LG GH22NP20
Corsair CMPSU-750TX
Antec Three Hundred
Logitech Z-4
I looked at the Asus P7P55D Pro, and it says: PCI Express 2.0 x16: 2 x PCIe 2.0 x16 (single at x16 or dual at x8/x8 mode) Would that slow down the GPU in Crossfire?
8x mode will only slightly affect Crossfire performance. The latest benchmarks show very little performance difference between 16x crossfire and 8x crossfire. x8/x8 is the best that any P55 board can do.
The purpose of the machine is mainly for gaming. Mainly playing NFS and Strategic games like CC3... I have a 22" Widescreen with a screen resolution of 1680x1050.
Would everyone agrees that i5-750 would be a better solution than i7-860 or i7-920?
Basically I am looking at either:
i7-860 with 2 x HD 5770
or
i5-750 with 2 x HD 5850
or
Thanks
I would definitely go with the i5 750 + 2x HD 5850. The graphics card makes more of a difference when it comes to gaming as opposed to the processor. Having said that, even one 5850 is a bit overkill for your needs. Just buy one 5850 for now, and get the second one in like a year's time as it will be considerably cheaper by then.
