Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > No monitor signal gtx 260/275
Forum Graphic & Displays : Graphics Cards - No monitor signal gtx 260/275
I just bought a new PSU today
http://www.newegg.com/Product/Prod [...] 6817153077
so i could upgrade my graphics card. First i got the GTX 275 and connected everything but my monitor got no signal. i tried a new monitor and switched some cables and that wasn't it. i put in my old gt120 and it worked fine.
i cleared all drivers, nothing. i got on the phone with tech support who said my new PSU should run it fine, ran me through everything i already tried and actually recommended i get a new card.
i return it, and get the GTX 260 and have the exact same problem.
the computer boots fine, i can feel the air from the card's fan moving, but my monitors get no signal. i do not have an integrated display on my board to disable.
my computer is
http://www.newegg.com/Product/Prod [...] 6883113089
i have had no problems i couldn't fix myself up until now.
any help would be greatly appreciated
Sponsored Links
have you tried your old video card to see if you get anything?
Reply to qryptiq
That PSU is a POS. It doesn't have active PFC, only has 70% efficiency, and doesn't have much power on the 12v rails. It's most likely that the PSU just can't produce enough clean power to run those graphics cards. I would return it for a quality unit from Corsair, Antec, Seasonic, PC Power & Cooling, or OCZ.
Here's a much better PSU that actually costs less.
OCZ Fatal1ty OCZ550FTY 550W ATX12V / EPS12V SLI Ready CrossFire Ready Modular Active PFC Power Supply - Retail $64.99 - $25 MIR + an additional 10% off with promo code OZSAVEOCT.
Reply to shortstuff_mt
ya i put in my old video card and it works fine.
i thought it might be the psu but the card turns on, i can feel the fan pumping. is it possible that there is enough power to start it up but not enough to send a signal to my monitor?
Reply to allerac83
Powering the fan on the GPU hardly takes any power. Properly powering the GPU is another story. I would return that POS PSU whether it's actually the problem or not. Using a cheap PSU like that is just asking for problems down the road. A cheap PSU can cause all sorts of problems ranging from system instability to fried components.
i'm going to return it today and get a corsair tx750w. a buddy of mine said its a solid psu.
i don't know if i should stick to the gtx 260 though. would it be worth it with my system to get an HD 5850?
Reply to allerac83
i just changed the psu to
http://www.newegg.com/Product/Prod [...] 6817371026
antec 750w
same problem with the new card. i then throw my pos gt120 in and it starts up without a problem. is there something that i am just missing here??
Reply to allerac83
You are plugging in the auxiliary power connectors?
------------------------------ [:mousemonkey:1] http://img29.imageshack.us/img29/5041/vr2009champ.jpg
Reply to mousemonkey
yup, that was the first the tech support asked me too. i'm plugging the PCI-E cables directly from the psu to the card
Reply to allerac83
There are 1274 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
