Tom's Hardware > Forum > Homebuilt Systems > New System Build > [Solved] Help with New Build
Forum Homebuilt Systems : New System Build - [Solved] Help with New Build
Best answer from niklas_13.
I am going for my first build. This is around the budget that I am trying to stick around +/- 100 is fine. But I have this picked out for my first build. I play more simple games like Heroes of Newerth, WC3, Call of Duty, etc.. Not hardcore games like crysis or anything. Any thoughts/help on my build would be greatly appreciated.
MSI 790FX-GD70 AM3 AMD 790FX ATX AMD Motherboard
AMD Athlon II X4 620 Propus 2.6GHz Socket AM3 95W Quad-Core Processor
G.SKILL 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
COOLER MASTER Storm Scout SGC-2000-KKN1-GP Black Steel / Plastic ATX Mid Tower Computer Case
COOLER MASTER Silent Pro 600 RS-600-AMBA-D3 600W ATX12V V2.3 SLI Certified CrossFire Ready
x2 - Western Digital Caviar Blue WD6400AAKS 640GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive
x2 - SAMSUNG Black 22X DVD Burner Black SATA Model SH-S223B - OEM
x2 - ASUS Radeon HD 4650 512MB DDR2 Crossfired. (I went with these because I already have one,
I did not add it to the price.)
All from NewEgg so the prices can be checked but you should know an average price for the item. Total price comes out to $775.
Thank you very much for your help.
***To add to post after another read. The graphics card, I added ONE to the price. Could sound like I meant both that I did not add, I added one. Also I do do alot of Photography stuff (Adobe CS4) on the PC, my wife is a Photographer. Any recommendations on screens would be great as well.
Message edited by Anonymous on 10-16-2009 at 12:54:49 AM
I like this CPU better, also has a combo with a mobo http://www.newegg.com/Product/Comb [...] mbo.272102
Sponsored Links
Do you really need such an expensive motherboard?
For video, you'd be much better served by purchasing a slightly higher spec card than another one of those 4650s. As 4650s go, it's low end--crippled a 64-bit memory interface.
If you're not concerned about performance then it won't be a problem, but not much more cash could get you much better gaming. I'm also not sure if you'd see a benefit from crossfire, some applications aren't helped by it at all.
The WD drives aren't the fastest, so don't expect above-average speed.
If you have a legitimate reason for two optical drives then by all means keep them, but that would be another to look if you want to make room in your budget for a better GPU.
Reply to tortnotes
Sony Optiarc 24X DVD/CD Rewritable Drive Black SATA Model AD-7240S-0B - OEM
Item #: N82E16827118030
Return Policy: Limited Replacement Only Return Policy
Protect Your Investment (expand for options)
$31.99 http://www.newegg.com/Product/Prod [...] 6827118030
Western Digital Caviar Black WD6401AALS 640GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Item #: N82E16822136319
Return Policy: Standard Return Policy
$74.99 http://www.newegg.com/Product/Prod [...] 6822136319
XFX HD-487A-ZWFC Radeon HD 4870 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - Retail
Item #: N82E16814150436
Return Policy: VGA Standard Return Policy
-$5.00 Instant $149.99
$144.99 http://www.newegg.com/Product/Prod [...] 6814150436
OCZ Fatal1ty OCZ550FTY 550W ATX12V / EPS12V SLI Ready CrossFire Ready Modular Active PFC Power Supply - Retail
Item #: N82E16817341022
-$20.00 Instant
$25.00 Mail-in Rebate Card
$89.99
$69.99 http://www.newegg.com/Product/Prod [...] 6817341022
Tuniq TX-2 Cooling Thermal Compound - Retail
Item #: N82E16835154003
-$2.00 Instant $6.99
$4.99 http://www.newegg.com/Product/Prod [...] 6835154003
Intel Core i5-750 Lynnfield 2.66GHz LGA 1156 95W Quad-Core Processor Model BX80605I5750 - Retail
Item #: N82E16819115215
Return Policy: CPU Replacement Only Return Policy
$199.99 http://www.newegg.com/Product/Prod [...] 6819115215
COOLER MASTER Hyper 212 Plus Intel Core i5 & Intel Core i7 compatible RR-B10-212P-GP 120mm "heatpipe direct contact" Long ... - Retail
Item #: N82E16835103065
$29.99 http://www.newegg.com/Product/Prod [...] 6835103065
COOLER MASTER RC-690-KKN1-GP Black SECC/ ABS ATX Mid Tower Computer Case - Retail
Item #: N82E16811119137
-$15.00 Instant
-$45.00 Combo $159.98
$99.98 http://www.newegg.com/Product/Comb [...] mbo.273732
GIGABYTE GA-P55M-UD2 LGA 1156 Intel P55 Micro ATX Intel Motherboard - Retail
Item #: N82E16813128405
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL7D-4GBRH - Retail
Item #: N82E16820231279
Return Policy: Memory Standard Return Policy
-$20.00 Combo $204.98
$184.98 http://www.newegg.com/Product/Comb [...] mbo.264221
Subtotal: $841.89
Maybe ?
Message quoted 1 times
Message edited by niklas_13 on 10-16-2009 at 02:45:38 AM
------------------------------ P55-UD4P / i5 750 / GSkill 1600 / WD Black 640 / HD 5850 / Corsair 750 / Win 7
Reply to niklas_13
Well, what would you suggest on a mobo, gpu, and hdd's? It is easier with the two drives with burning cds for customers on the photography side. (Large amounts of photos.)
Reply to Anonymous
-$20.00 Instant
$89.99
-$15.00 Instant
Subtotal: $841.89
Maybe ?
Thank you for the reply, I have thermal compound. Would also like to have 2 CD drives. I have always been an AMD fan so I would love to stick with AMD CPU plus isnt the power close to the same but this one is $100 Cheaper?
How about this : Same as I have listed, changes to this:
ASUS M4A77TD Pro AM3 AMD 770 ATX AMD Motherboard - Retail $89.99 almost half the price as the other one.
x2 - HIS H467QS1GH Radeon HD 4670 1GB 128-bit DDR3 PCI Express 2.0 x16 HDCP $149.98 I subtracted the 54.99 for the other card, or I could go with the same card you suggested for the same price.
The box/HDD combo and the cooling unit you had suggested.
Total: $766.90
Reply to Anonymous
here's a cheap 4870 i have in my computer works great
POWERCOLOR AX4870 512MD5 Radeon HD 4870 512MB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card Retail- http://www.newegg.com/Product/Prod [...] 6814131140
Message edited by nun on 10-16-2009 at 04:26:13 AM
Reply to nun
the one i posted has 512MB more ram for 18 bucks
Reply to niklas_13
Best answer
Reply to niklas_13
There are 1080 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 04:06 xyz001 won the Sophmore badge
  • 01:00 scione won the Freshman badge
  • 01:32 aford10 won the Home Brew badge
  • 01:00 Kevinator won the Uniformed badge
  • 01:00 adis won the Uniformed badge
  • 01:00 dabell won the Uniformed badge
  • 01:00 zebo56 won the Uniformed badge
  • 01:00 drkkmittal won the Uniformed badge
  • 01:00 jakesvdyk won the Uniformed badge
  • 01:00 artistjane won the Uniformed badge
