Tom's Hardware > Forum > Homebuilt Systems > New System Build > Before buying parts. Give me your feedback please.
Forum Homebuilt Systems : New System Build - Before buying parts. Give me your feedback please.
Hey guys, I'm about to be buying my PC, and i was wondering if you guys would give me your feedback on the system i'm getting. Any suggestions would be most appreciated.
Thanks.
MOBO
MSI 790FX-GD70 AM3 AMD 790FX
http://www.newegg.com/Product/Prod [...] 6813130223
CPU
AMD Phenom II X4 965 Black Edition Deneb 3.4GHz
http://www.newegg.com/Product/Prod [...] 6819103692
CPU COOLING
Sunbeam CR-CCTF 120 mm Core-Contact Freezer CPU Cooler
http://www.newegg.com/Product/Prod [...] 6835207004
RAM
G.SKILL 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600
http://www.newegg.com/Product/Prod [...] 6820231193
PSU
Thermaltake W0116RU 750W
http://www.newegg.com/Product/Prod [...] 6817153038
GPU
XFX HD-587A-ZNF9 Radeon HD 5870
http://www.newegg.com/Product/Prod [...] 6814150443
Please let me know, I'm still trying to figure out if the RAM is good. and if PSU will be sufficient.
Thanks again.
Sponsored Links
That should be one sweet system.
The PSU is large enough for your current setup - although like may others I would recommend Corsair PSUs. Do you want to leave room to Crossfire and/or OC the CPU and/or video card? If so I would go larger - perhaps to 1000w. In their review comparing Crossfire 4870s and SLI 285s, and using your CPU among others, THG used an 1100 watt PSU. Off course your video card has a smaller power requirement - but I don't think they OC - but still probably left headroom.
http://www.tomshardware.com/review [...] 403-3.html
Have you run it through the power calculator? It would probably be worthwile to pay the nominal fee to use the Pro version that provides the ratings for each volt level. Unfortunately my subscription has run out and I have not need to extend.
http://www.extreme.outervision.com/psucalculator.jsp
Is there a reason you selected the Sunbeam cooler over more common choices like the Xigamatek Dark Night?
I prefer the Gigabyte boards for the UD features - but MSI is good too . Did you see this article?
http://www.tomshardware.com/review [...] ,2277.html
I won't comment on RAM because I don't have a lot of experience with different varieties.
------------------------------ There are 10 kinds of people in the World...Those who understand binary, and those who don’t!
Reply to rockyjohn
Do you need an FX mb? Only spend the extra if you will definitely crossfire , otherwise you can save some money with a 790 g or 790x
The Phenom 965 is the exact same part as the 955 , but it is overclocked a little by AMD . You can do this yourself and save money. Both OC to the same level .
The RAM you picked has only OK timings . Its 9-9-9-24 . Lower is better and if you read the memory articles on this site you can see that 1333Mhz with 7-7-7-20 is just as quick .
Your RAM is really 1333 MHz but they are running it at 1600 MHz but slackened the timings so its stable . There is definitely better ram available .
You havent mentioned a hard drive . The fastest mainstream drive is the samsung f3 500 gig .
You have a great build already but a little tweaking will save you some $$$$
Reply to Outlander_04
I really don't think i'll go crossfire, so 1000+ watt PSU is overkill i think, What PSU would u recommend?
As for HDD i'm planing on getting
Western Digital Caviar Black WD6401AALS 640GB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5
http://www.newegg.com/Product/Prod [...] 6822136319
It's a part of a deal with CM 690 and saves me 60$.
Which MOBO would you recommend? for my set up?
And from what I've heard before is that Dark Knight not compatible with AM3 sockets. And I've asked on forums here, and people recommended that CPU cooler. Is that not so?
Reply to jvwash
Definitely drop down to the 955, it will save you $55 and has an unlocked multiplier so you can set it 1 high and have a 965 for free.
The 790GX board still gives you the option of crossfire down the line while saving you a fair amount
http://www.newegg.com/Product/Prod [...] 6813131366
$9 more gets you ram with tighter timings, though that gskills kit you currently have listed has an XMP profile for 8-8-8-24 at 1.6v, i will probably play with mine tomorrow night and see if i cant get the ripjaws timings out of them at similar voltages.
http://www.newegg.com/Product/Prod [...] 6820231279
If you are pretty sure you arent going to crossfire a corsair 550vx would be fine
http://www.newegg.com/Product/Prod [...] &Tpk=550vx
Message edited by hunter315 on 10-16-2009 at 02:33:39 AM
Reply to hunter315
BTW. What do you think about this Mobo/Cpu?
CPU
Phenom ii x4 955BE
Mobo
http://www.newegg.com/Product/Prod [...] 6813128387
It would save me like 70$.
Reply to jvwash
For a rig like this that you wont add a second gfx card then a 650 watt psu gives you plenty of overhead . That will let the psu run without being stressed or getting hot .
The corsair 650 tx has been very popular because its a good combination of price and quality
http://www.newegg.com/Product/Prod [...] 6817139005
$80 after rebate
The mb in your combo is an AM2+ mb that runs DDR2. For future proofing stick with an AM3 mb and DDR3
The WD black is a good drive , and I use one in my home computer . But the newer Samsung F3 is faster, and quieter so if you dont need the extra storage its a better buy .
Message edited by Outlander_04 on 10-16-2009 at 02:59:39 AM
Ok, guys look at this and let me know what you think.
MOBO
GIGABYTE GA-MA790FXT-UD5P AM3
http://www.newegg.com/Product/Prod [...] 6813128377
CPU
AMD Phenom II X4 955 Black Edition Deneb 3.2GHz
http://www.newegg.com/Product/Prod [...] 6819103674
CPU FAN
GPU
HD 5870
Trying to get XFX
RAM
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333
http://www.newegg.com/Product/Prod [...] 6820231276
PSU
CORSAIR CMPSU-650TX 650W ATX12V / EPS12V
HDD
HDD comes with the case and saves me like 60$.
CASE
COOLER MASTER RC-690
http://www.newegg.com/Product/Prod [...] 6811119137
DVD
LITE-ON Black 4X Blu-ray Reader
http://www.newegg.com/Product/Prod [...] 6827106325
Let me know what you guys think.
Thx.
Reply to jvwash
Pretty good, but i would still suggest the 790GX or 790X rather than the 790FX, unless you need quadfire or intend to get a 5870X2 to run in trifire you wont get a performance hit from 8x/8x crossfire.
Reply to hunter315
Whoops, didn't notice Outlander already pointed this out. Sorry
Message edited by jbakerlent on 10-16-2009 at 05:11:24 AM
------------------------------ How To Ask For Build Advice
Homebuilt PC Buying Guide
Reply to jbakerlent
ok, i'm getting the F3,
and hunter315
Could you give me a link to the best Mobo in your opinion between GX or X. Newegg would be the best place for me to buy i would think.
Please and Thank you.
Would this combo work?
http://www.newegg.com/Product/Comb [...] mbo.272972
Message edited by jvwash on 10-16-2009 at 05:14:10 AM
Reply to jvwash
O i like that one, and newegg has a combo of that with 955BE :P
That helps a lot.
Thx
Reply to jvwash
I really think you should leave open the option to crossfire if you later want to double up the video performance as games require more or if you want a bigger monitor. With that system and the larger PSU you could subtantially increase power by just adding another video card later. Why spend more for a crossfire capable mobo but not get a larger PSU to accomodate it? The 750w version of that PSU only costs $20 more and that extra 100w could make a big difference if you become interested in crossfire
Message edited by rockyjohn on 10-16-2009 at 05:27:03 AM
Reply to rockyjohn
Ok, say I decide to go Crossfire, What PSU would you recomend? (link to newegg if not too much trouble)
and what MOBO would you recommend? I assume it would have to be a Mobo with 16x 16x PCI, so like
would be good for it?
Reply to jvwash
No, the 790X supports 8x/8x crossfire which wont inflict any noteable performance penalty vs 16x/16x crossfire. Normally we suggest a 750 watt PSU like the corsair 750TX or the antec TP-750
Reply to hunter315
So, keeping the
MOBO
http://www.newegg.com/Product/Prod [...] 6813131402
And getting
PSU
And the F3 HDD.
And i'm keeping the rest of the stuff.
Does that sounds like a good build?
Reply to jvwash
I think you've got it - except that your PSU link above is not the PSU but the same link as the mobo and I am not sure about the RAM.
Here is the Corsair 750TX PSU
http://www.newegg.com/Product/Prod [...] 6817139006
ON the RAM, jvwash last listed this:
Which is a different speed than what hunter listed:
And both state right at the top "Dual Channel Intel Core i5 & Core i7 CPU for P55 motherboard"
On the spec page, one states "Specifically Designed to compatible with Intel Core i5 and Core i7 for Intel P55 motherboard"
Which is the right one? Are you sure they are compatible with the ASUS 790X board and good for OC on that board?
Message edited by rockyjohn on 10-16-2009 at 06:32:11 AM
Reply to rockyjohn
yeah, sorry the PSU is the Corsair 750TX.
About RAM, i'm still not sure, Which would be the better one, and how would i find out if it's compatable with ASUS 790X and good for OC?
That's the biggest problem i'm having right now, Which RAM would be the best.
Any help?
Reply to jvwash
By the way, out of curiosity I looked up the 5870 cards on newgg. They have 6 cards listed, including the XFX you chose, but they are out of stock of all of them except one - HIS.
I also found this review/comparison of 3 of the cards, including HIS and XFX. The bottom line is that they all basically have the same performance (no surprise) so its the standard advice to select on features and price. The latter is not much help as newegg lists them all at between $380 and $390. Based on the diffent features for the three tested - I would have chosen the XFX as well.
http://www.driverheaven.net/reviews.php?reviewid=853
Reply to rockyjohn
Yes, I will probably wait till XFX will come in stock, which they say should be this coming Monday, so i'll be getting it then if i get it.
XFX mainly because of the Double Lifetime warranty, which i really like.
But the main problem right now is, which RAM would be the best, I'm trying to go just under 100$, from what i've heard, the 7-7-7-20ish, is best. So i'm wondering which would be the best.
Jvwash.
Reply to jvwash
if you open to it the i5 outperforms the 955/965
Reply to obsidian86
I wondered about that myself when this thread first started, but than I read this THG review which seems to show otherwise - they are about equal.
http://www.tomshardware.com/review [...] ,2403.html
And since OP is going with an even faster AMD video card than used in the review, I figured that gives the edge to them. Also, as far as flexibility and ugradability goes, I am much more impressed with AMD sticking with compatible CPU slots than Intel with all their changes.
That said, if I were building a new system today I would probably go with i7 - either the i7 870 (to keep the hyperthreading) or maybe even the higher priced i7-920 to stay with the top end system. Hoever I am hard pressed to recommend those to others over the i5 given its outstanding performance and low price.
But the 955/965 is a very good and choice also, equal to the i5, and I cannot see trying to get someone to change away from it given the review.
Reply to rockyjohn
well considering the i5 is at 2.66 ghz and is equal too the amd 955/965 at 3.2 ghz and 3.4 ghz
Reply to obsidian86
What is your point? I really have no idea since the speed of the CPU by itself tells little.
Reply to rockyjohn
I was thinking about i5, or even the i7 920, but budget is somewhat tight, and I'm really "scared" to what Intel is doing with their sockets. going to i7, and then releasing i5 with a different socket, just a bit crazy.
Reply to jvwash
What do you guys this about this RAM for the build?
FYI... mobo is the Asus 790X
yeah...
But yeah, the RAM.. would this run with it?
http://www.newegg.com/Product/Prod [...] 6820226076
Reply to jvwash
There are 533 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
