My 915 gav motherboard has an auxiliary pwer connector on it (4 pin molex).if i connect it will my pci-e slot supply more than 75 watts so that i can overclock my 9800gt green.
Probably worth a try, but it will most likely just help it to maintain the voltage more consistently. Even so, this could help you OC more stably to a point.
is it?
I have a problems, i cant boot up my system with the 5750 from xfx
Power supply, cooler master gx550
I didnt plug in the molex on the mother board...
Anybody can help?
