I'm needing an aftermarket CPU cooler, not sure if I should get a closed water cooling system or an air cooler. i was thinking about getting one of the corsair HXX series water coolers, are those any good or could i get a better air cooler for the money.
I'm leaning towards a water cooler because they take up less room in the case and they wont block the ram slots.
I've heard that Cool Master is coming out with a vapor chamber cooler in about a month, but i'm not sure what kind of performance that will have or the physical size of it.
I would prefer to spend under$100 but I can go a little over if i really have to
Do you recommend recomend water of air and what cooler?
Thanks
CPU-Intel i7 950
Motherboard-Asus Sabertooth X58
Graphics Card-MSI Twin Frozer II GTX 560 Ti*
RAM-6 GB Corsair Dominator 1600**
PSU-Corsair TX750
HDD-Western Digital Caviar Black 1 TB
SSD-Intel 320 80 GB
Case-NZXT Phantom Black full ATX
*Possibly adding a second graphics card in sli
**I'm about to replace this with a 12GB (3x4GB) G.Skill ripjaws 1600 and possibly a second set of these later.
Thanks
CPU-Intel i7 950
PSU-Corsair TX750
SSD-Intel 320 80 GB
