Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > Abit NF7-S Starting problem
Forum Homebuilt Systems : General Homebuilt - Abit NF7-S Starting problem
Well i was installing a new hard dirve and it didn't recognize it so i powered down and changed the pin setting on the hard drive, then restarted the pc and it wouldn't do anything but power everything up and the monitor stayed black no idea whats going on iam pretty sure all the cables are connected correctly, any idea's?
Sponsored Links
Make sure the video card is attached securely to the mobo(assuming you have a video card) and make sure the DVI or VGA cable is conected on both ends.
Its pretty hard to put things in wrong as most things will only fit one way unless you force them.
Reply to Techn9ne1730
- 0 +
Well normally when its started it will do that little beep noise and go to a black screen showing all the hardware but it doesn't even do that beep now.
Reply to ebnick
There are 1160 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 vianescute won the Freshman badge
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
