I am buying a 2500k i5 CPU and I want to overclock it in the future. The case I am getting is an Arvina Extreme Series by Sentey so the cooler I need, needs to be able to fit inside that case. It's a full atx tower (atleast that's what newegg says) so there should be enough for any cooler, but I am not entirely sure what will fit and what wont. Please check the specs here:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811322006
Here is the cooler I was thinking of getting:
http://www.newegg.com/Product/Product.aspx?Item=N82E16835288001&Tpk=EVGA%20Super%20Clock
The problem is, now that I am getting a Arvina case, I need to get a Blue LED cooler. The Arvina case has blue LED lights and it would look weird with a red LED cooler. Is there a blue version of this cooler? Is there a sufficient cooler that has a blue LED fan? Please do not suggest a Cooler Master Hyper 212 cooler. I was thinking of getting the EVO version of that but then found out how big it was and I am not willing to give up a RAM slot for a cooler. What do you think of the ZALMAN cooler?:
http://www.newegg.com/Product/Product.aspx?Item=N82E16835118223
If there is a cooler that is $50 or less that will fit in that case and doesn't have a blue LED but is better, I will take it. I just want to give my build a good look. Btw, this is my mobo if it will help at all:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130583
I am going to be doing SLI GTX 460. And I am going to be using 8GB (2x4GB) Black Corsair Vengeance RAM. I do NOT want a cooler that will cover up a RAM slot. I know the Vengeance ones are tall.
Thanks for your help!!!!
