Tom's Hardware > Forum > Homebuilt Systems > New System Build > Low Power cheap general usage build
Forum Homebuilt Systems : New System Build - Low Power cheap general usage build
APPROXIMATE PURCHASE DATE: Soon, dont really have a set date. By years end BUDGET RANGE: hopefully around $300
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: HD movie watching/ streaming, internet, programming.
PARTS NOT REQUIRED: keyboard, mouse, monitor, speakers, OS PSU = anything that will fit into a HP slimline
PREFERRED WEBSITE(S) FOR PARTS:newegg.com, ncix.com COUNTRY OF ORIGIN: USA
PARTS PREFERENCES: i was leaning towards a intel celeron/ AMD regor platform.
OVERCLOCKING: NO SLI OR CROSSFIRE: NO
MONITOR RESOLUTION: 1680x1050, probably dual head in the future
ADDITIONAL COMMENTS: I would like a quiet PC, I currently have a HP slimline s7220n which doesnt make any noise
MOBO specs i would like:
  • HDMI DVI.
  • NO vga.
  • wake on lan and optical or spdif out for sound
  • Gigabit ethernet
I will be running windows/linux on it.
only parts i know that i want are
Samsung spinpoint F3
http://www.newegg.com/Product/Prod [...] 6822152181
WD caviar black 500gb
http://www.newegg.com/Product/Prod [...] 6822136320
AMD athlon II X2 Regor
http://www.newegg.com/Product/Prod [...] %20II%20X2
Message edited by rubenvazquez on 10-18-2009 at 03:26:43 AM
Sponsored Links
The best onboard gfx available are on AMD's 780g, 785g abd 790g chipset motherboards .
They are a lot better than the intel G41/43 chipsets .
A budget AMD build is probably going to be based on the Regor 240 cpu which is a celeron equivalent .
You should be able to get a stock cpu cooler from an AMD quad on ebay or from a local shop very cheaply since many will have been replaced with aftermarket coolers .
The higher capacity AMD cooler will run quieter than the smaller cooler that ships with the regor
Message quoted 1 times
Message edited by Outlander_04 on 10-18-2009 at 02:45:05 AM
Reply to Outlander_04
I see that the athlon uses ddr3. Is that more or less expensive than ddr2? What about the phenom. Is that comparable do a celeron/athlon
Reply to rubenvazquez
I would get a AM2+ board which utilizes DDR2 given your budget. I would stick to the Athlon II again because of your budget.
------------------------------ How To Ask For Build Advice
Homebuilt PC Buying Guide
Reply to jbakerlent
all i see for athlon II is the regor models which are am3 unless im missing something
It's a bit confusing, but all AM3 CPUs can fit in AM2+ motherboards. However, AM2 CPUs do not fit in AM3 boards...
Reply to jbakerlent
There are 1122 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
