Tom's Hardware > Forum > Homebuilt Systems > New System Build > $1k budget, recycling some old parts.
Forum Homebuilt Systems : New System Build - $1k budget, recycling some old parts.
Parts not required: Keyboard/mouse, optical drives, sound card, speakers, or monitor. I wont be recycling my case as its getting a bit dated, I prefer full size towers.
I am looking for a crossfire setup, preferably an AMD processor as they seem to be a bit cheaper than i5/i7. Mainly this computer will be used for Operation Flashpoint: Dragon Rising, hoping to run it at very high settings. Any input would be appreciated :)
Edit: I will be purchasing within two weeks.
Message edited by rfsebben on 10-19-2009 at 12:07:55 PM
Sponsored Links
phenom ii 945 95w
5870
4gb ddr3
790fx-gd70
antec 1200
caviar black
------------------------------ "Envy is ignorance" - Henry Thoreau : Best quote ever.
http://www.pingtest.net/result/3022953.png
Reply to xaira
Case: Lian Li Lancool PC-k 62
http://www.newegg.com/Product/Prod [...] 6811112239
HDD Samsung Spinpoint f3
http://www.newegg.com/Product/Prod [...] 6822152181
PSU Corsair's 650watt modular (imo, should be more than adequate to crossfire 5850's down the line for me)
http://www.newegg.com/Product/Prod [...] 6817139012
Ram Mushkins,
http://www.newegg.com/Product/Prod [...] 6820146871
Mobo/CPU Combo deal msi 790fx-gd70 and phenom ii x4 965 with free canon printer, worth the 10 bucks to step up to 965 and a free printer imo
http://www.newegg.com/Product/Comb [...] mbo.270577
5850
Some cold cathodes, think it will make the K-62 even sexier
http://www.newegg.com/Product/Prod [...] 6811994001
Prolimatech Mega Shadow + Am3 retention adapter
http://www.frozencpu.com/products/ [...] html#blank
Going to push pull with a pair of Scythe S-flex's
http://www.newegg.com/Product/Prod [...] 6835185065
A 38mm large fan would be more ideal, due to the static pressure; but the Mega Shadow only comes with 2 pairs of 25mm fan brackets. And I can't find a san ace 38mm anywhere, so not really a big deal for me.
This is the build I'll be getting in the mail this week. Naturally you can change out the case and 5850 for a 5870 or the 650watt PSU for a larger supply like the 750TX from corsair, but this should give you an idea as to what you're looking for.
Message edited by ominous prime on 10-19-2009 at 04:07:47 PM
Reply to ominous prime
There are 1094 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
