Archived from groups: comp.sys.laptops (More info?)
Hi All
I recently purchase a Toshiba Satellite - P25 Series.
Last night Inoticed that when the laptop was turned of the power supply was
making a loud ticking noise, if I unplug the power supply from the laptop it
stops or if I unplug the supply from the mains it stops.
It depends, really, on exactly how loud it is. The power supply, being a
switchmode power supply, is sophisticated, and depending on the required
power output it changes modes. When the laptop is off and doing nothing,
it still takes a tiny amount of power from the power supply. The power
supply will thus switch on very briefly but often, which is the ticking
noise you describe. So that's the idea.
> Any ideas ? ?
> Is this unsfae to use ??
If it is very loud, it could mean that it's not in great condition and
may need to be replaced. I doubt that it is unsafe if you are near it,
but there is a small possibility that it would be a fire risk so
probably don't leave it unattended unless you're confident it's ok.
Summary: very quiet noise is ok and normal, very loud noise is possibly
a bad sign and get it looked at before you leave it plugged in by itself.
Cheers, hope that helped a bit though I know it's far from conclusive advice
Peter
