$700 System
Forum Homebuilt Systems : New System Build - $700 System
APPROXIMATE PURCHASE DATE: this week
BUDGET RANGE: 600-800 Before / After Rebates
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: Homework, AutoCad, Solidworks, MatLab, VisSim Engineering Programs.
PARTS NOT REQUIRED: keyboard, mouse, monitor, speakers
PREFERRED WEBSITE(S) FOR PARTS: Any, newegg.com is most common.
PARTS PREFERENCES: Intel CPU
OVERCLOCKING: no
MONITOR RESOLUTION: Will purchase monitor based on system.
ADDITIONAL COMMENTS:
Not a gaming machine, however would Like it to run Cad and Engineering
programs such as Solidworks AutoCad etc. smoothly. Need advice on O/S ram / SPU etc. Any Ideas? I need the tower only, keyboard monitor and so forth I already have. Any help is very appreciated. Thanks.
Message edited by weech on 10-19-2009 at 10:58:44 PM
Sponsored Links
Please edit your post to follow the format layed out in the "How to ask for new build advice" sticky. There's some information in there that will help us recommend a build. It's hard to recommend components without knowing where you live, for example.
Reply to shortstuff_mt
Was in the process of that :/
Reply to weech
A Pentium Dual Core for AutoCad, Solidworks, MatLab, VisSim, etc...? I don't think so. Here's a powerful system that would work great for your needs at your budget:
Intel Core i5 750 Lynnfield 2.66GHz 8MB L3 Cache LGA 1156 95W Quad-Core Processor - Retail
http://www.newegg.com/Product/Prod [...] 6819115215
GIGABYTE GA-P55-UD3R LGA 1156 Intel P55 ATX Intel Motherboard - Retail
http://www.newegg.com/Product/Prod [...] 6813128401
http://www.newegg.com/Product/Comb [...] mbo.270435 $324.98 (CPU + motherboard combo)
Antec Three Hundred + BP430 Black Steel ATX Mid Tower Computer Case 430W Power Supply - Retail
http://www.newegg.com/Product/Prod [...] 6811129065 $79.99
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL7D-4GBRH - Retail
http://www.newegg.com/Product/Prod [...] %207%204gb $94.99
SAMSUNG Spinpoint F3 HD502HJ 500GB 7200 RPM 16MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive - OEM
http://www.newegg.com/Product/Prod [...] 6822152181 $54.99
Microsoft Windows 7 Home Premium 64-bit 1-Pack for System Builders - OEM
http://www.newegg.com/Product/Prod [...] 6832116754 $99.99
SAPPHIRE 100295HDMI Radeon HD 4670 512MB 128-bit GDDR3 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - Retail
http://www.newegg.com/Product/Prod [...] 6814102854 $66.99 - $10.00 MIR
SAMSUNG SH-S223B 22X SATA DVD Burner Black Drive Bulk
http://www.zipzoomfly.com/jsp/Prod [...] t=celebros $29.99
Total - $751.92 - $10.00 MIR
You could drop the system price another $25 if you use this CPU + motherboard combo:
http://www.newegg.com/Product/Comb [...] mbo.270438 (i5 750 + Gigabyte GA-P55M-UD2 combo) 299.98
Message edited by shortstuff_mt on 10-19-2009 at 11:21:57 PM
Many Thanks on the systems.
Reply to weech
Tom's Hardware > Forum > Homebuilt Systems > New System Build > $700 System
There are 661 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 raulkm won the Uniformed badge
  • 01:00 letus won the Uniformed badge
  • 01:00 pmiddy won the Uniformed badge
  • 01:00 MarcieMark won the Uniformed badge
  • 01:00 kaypeezee won the Uniformed badge
  • 04:06 xyz001 won the Sophmore badge
  • 01:00 scione won the Freshman badge
  • 01:32 aford10 won the Home Brew badge
  • 01:00 Kevinator won the Uniformed badge
  • 01:00 adis won the Uniformed badge
