Plenty. The HD 5770 uses less power than the HD 4850 which uses 110w.
I believe the HD 5770's power consumption is roughly 80w - 90w under typically gaming scenarios. That works out to 6.67a - 7.5a.
Benchmarking tools like FurMark will cause the video card to draw more power than normal gaming because FurMark is designed to stress everything the video card has to offer at the same time. Games do not do that. See the chart below for the HD 5870.
Based on the review, the HD 5870 typically consumes 107w of power when gaming. Some games stress the video card more than others so do not consider 107w to be the absolute max. As you can see FurMark stress test pushes power consumption up to 161w which is almost a 60% increase.
------------------------------Q9450 |Corsair XMS 4GB DDR 800 | ABit IP35 Pro | HD 5850 | Audigy 2 | Seasonic S12 550 | Cooler Master Centurion 532 | NEC LCD2690WUXi and Planar PX2611w | WinXP
Peace on Earth by means of the destruction of all life on Earth.
Reply to jaguarskx
HP p6280t which looks to have a 300w power supply. However, I would like to buy an ATI, perhaps the 4000 or 5000 series (running city of heroes presently no a 6 year old pc) but I keep reading about the power requirements?
Do I need to replace the power supply after I buy it?, like for example if I get a 5770 from radeon?
