APPROXIMATE PURCHASE DATE: Early November
BUDGET RANGE: ~ $1300 USD
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: Gaming, Excel, Internet Surfing
PARTS NOT REQUIRED: keyboard, mouse, monitor, OS)
PREFERRED WEBSITE(S) FOR PARTS: newegg.com & bestbuy.com
COUNTRY OF ORIGIN: USA
PARTS PREFERENCES: Intel CPU and probably going to try ATI for graphics (will be first time I buy an ATI card vs Nvidia)
OVERCLOCKING: Probably Not, but may later in life
SLI OR CROSSFIRE: A single raedon 5870 to start with, but want possibility to throw in another in crossfire down the road
MONITOR RESOLUTION: 1680x1050
ADDITIONAL COMMENTS: I'm mainly just looking for general thoughts about this build, and if there are any suggestions on things to change slightly. I'm going with lga 1366 so I can have the option to upgrade the CPU later without having to change the motherboard. My current build is a p4 3ghz, Geforce 7800gs, a system that I have had for umm, quite awhile, so I'm sure anything will be a huge upgrade
A couple of questions: Is there any reason I would not be able to throw in another 5870 in a year or two? Will two 5870s fit in this case? Also, I am undecided on a motherboard
But here is the build I've settled on right now:
CPU: Intel Core i7-920: 2.66GHz I kind of wanted to go with a Lynnfield but wanted 1366 for upgrade in the future ~ $280
Motherboard: Kind of at a loss on this one. Just seems to be quite a selection to choose from. Any I would buy would have to support triple channel, at least DDR 1333 with 6 slots. Onboard audio & LAN. Looking to spend about ~ $240
Memory: Large selection here too and I'm not sure what to go with. Looking for 6GB(3x2GB) DDR3 1333 or higher ~ $150
Powersupply: CORSAIR CMPSU-850HX I went with 850 W for if I go with Crossfire later on. Or is 850 W still too much? ~ $200
Video: Raedon 5870 I also haven't chosen a brand for this. Any suggestions, or ones to stay away from? And hopefully this price will be lower by the time early November rolls around ~ $390
Thanks for the combo find! I had forgotten to look for combos, so hopefully that will save me a bit more. And sorry that I forgot to mention the OS. Thankfully I have access to an email account for a university, so I was able to snag a copy of Windows 7 Professional 64bit that will be waiting on me after the 22nd.
I have the Western Digital Caviar Black 640 GB and it's pretty great, but the benchmarks for the Samsung Spinpoint F3 1 TB and 500 GB show that those drives are even faster with single 500 GB platters. Review here: http://www.bit-tech.net/hardware/s [...] b-review/1
Also, two 5870s in crossfire might be overkill on a 1680 x 1050 monitor unless you plan on upgrading the monitor later, but yeah you probably are.
