Hello TH peeps,
I recently did the "take off your side panel and blow a home fan into your case" test. While the fan itself didn't seem to do much in the way of cooling anything, having the side panel off did net me about 3 degrees (Celsius).
My case setup...
- Antec 1200 (original)
* 3 original front case fans (intake)
* 1 internal-bay Antec Tri-cool (blowing on the GPU's)
* 1 side Antec Tri-cool (intake)
* 2 original back case fans (exhaust)
* 1 original top case fan (exhaust)
All fans are running at their max speed...Performance > Noise for me
My question is, will I benefit (lower temps) from upgrading my case fans? Or have I just reached the max potential of this case? Would it be more prudent to just save the money I'd spend on fans and put it toward a better case?
Thanks,
Drew
PS: Also, I just ordered an H100. Will I benefit (again, lower temps) if I upgrade the fans on it?
My case setup...
Thanks,
Drew
