40+ Inch Monitor
Forum Graphic & Displays : TV/Video Cards - 40+ Inch Monitor
I'm planning on building a computer soon and I thinking about buying a 40 inch monitor and sitting 7-15 feet away from it in a recliner. The monitor is an Toshiba 40RV525R 40" Full HD LCD TV - 1080p, 1920x1080, 10000:1 Dynamic, 16:9, 3 x HDMI, S-Video, PC Input, which is an HDTV. Going to probably have a Radeon 8500 and an i7 processor. I'm worried about viewing text on programs and browsing the internet. Not sure if I'll have complications or not, any advice?
Sponsored Links
The minimum and maximum recommended viewing distance of a 40" TV is 5' to 9'. For a 15' viewing distance, a 60" screen is recommended. Keep that in mind when setting up your system.
If the video card has it, an HDMI to HDMI connection would be preferred but a DVI to HDMI cable or converter will work just as well.
If you have the Radeon with 128MB VRAM, that might be the bare minimum for a 1080p picture and resolution.
Text on programs and internet browsing can be adjusted through the OS. Both Windows and Linux allows you to customize the default font size, icon size, icon spacing, text shadowing, window sizes, menu styles, etc. So, with some time and a little tweaking, you can customize the windows GUI to meet your viewing needs.
Message edited by chunkymonster on 10-30-2009 at 01:55:37 PM
------------------------------ ASRock X58 Extreme - Core i7 920 - 6GB Crucial Ballistix DDR3 1600 - Sapphire 4890 2GB - Creative Xtreme Gamer - 4-80GB WD in RAID0 on HighPoint RR 2310 as OS drive - 1-320GB WD scratch drive - Corsair CMPSU 750TX - HAF 932 - Hanns-G 281DPB @ 1900x1200
Reply to chunkymonster
8500 was a mistype... meant 5850, sorry bout that didn't realize i did that. Thats all I was curious about though, thanks for the help.
Reply to hitta
Tom's Hardware > Forum > Graphic & Displays > TV/Video Cards > 40+ Inch Monitor
There are 1250 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
