Tom's Hardware > Forum > Homebuilt Systems > New System Build > AMD power build under $900
Forum Homebuilt Systems : New System Build - AMD power build under $900
So, I've found a ton of valuable information on this site, but one thing I can't decide on right now in my AMD build is which mobo to go with. Sofar, I am thinking of a Phenom II x 4 955 or 965 CPU, but which gx/fx mobo to go with eludes me. Any recommendations? Definitely going to get a VUd card, not sure which though, thinking a Radeon 4870, but again, not sure. As far as other things go, I am thinking something along the following...
I'd like some high end memory "1600 lat7 is prefferable, or is there anything better in an AMD build?)
750 watt corsair psu I found at Newegg for $99, thought that would be enough power
640 gb Black Caviar WD HD drive, seemed like one of the fastest/most reliable non SSD or raptor drives
An optical drive with lightscribe
Any recommendations for this under $900 build? And is the 955 really more reliable than the 965? I already have a few builds in mind, but would like to see you inputs first to see how well that matches up with what my research has got me already. Thanks in advance for any and all help, I really appreciate it!
Sponsored Links
Please you use the template provided at top of forum makes it much easier
------------------------------ Saving up for new ipod touch cant wait
Reply to admin123
There are 1050 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
