Tom's Hardware > Forum > Homebuilt Systems > New System Build > Help upgrading new system
Forum Homebuilt Systems : New System Build - Help upgrading new system
Hey guys im thinking of upgrading my GPU from my old 7600GT and was hoping u guys could lend me some advice...
I am limited to ordering from overclockers.co.uk since not many reliable sites deliver to Malta.
My other specs:
CPU: Q6700 @ 2.7Ghz
RAM: 4Gb (2x2Gb) DDR2
OS: Windows 7 64bit
PSU: (also changing see below)
Mobo: 4Core1600P35-WiFi from ASROCK
Ok now i'm leaning to the 4870 or the 4890....now my dilemma is that down the line i was going to Xfire the card with another 1 now the thing is when i looked at benchmarks i saw that the 4870x2 ranked very high up on lists whereas the 4890x2 was not even seen on the charts...so is the 4890 not good when Xfired??? as if the 4870 is better Xfired then i guess i should go for that no???
My next dilemma is that my PSU needs changing as it can barely run 1 of these GPUs let alone 2 lol
A friend recommended at least a 700W PSU...and i found this:
http://www.overclockers.co.uk/show [...] =CA-032-OC
now the thing is it says that its SLI certified not Xfire....does this mean that it will not run them??
If you can please suggest a good PSU doesn't have to be modular but people tell me a good brand is essential.
Also I am also not 100% my mobo will take the 2 GPUs on my manual it says that it is Xfire certified but the thing is both the 4870 and 4890 are not listed in the GPUs on the manual, so im not sure if it will run it...if i do need to change it i will when i get the 2nd card later on just wondering if you guys would know if it would work or not.
Thanks a lot in advance for all your help guys its well appreciated
XoN
Sponsored Links
no1 wanna give some advice?? :cry:
or did i do something wrong in the description??
Reply to xon_8
ok a suggestion leave the dual cards for now grab a 5870(5-10% behind a 4870x2) and a corsair 750 watt
Message edited by obsidian86 on 10-20-2009 at 06:32:55 PM
Reply to obsidian86
- 0 +
well my budget is around the amount of a 4870/4890 and then later on ill have enough for another 1 thats y i chose the dual core the 5870 goes over my budget for thet time being i need to get just 1 card plus 1 PSU that will be able to take 2 cards later on....
so my budget for both PSU and GPU is ~200GBP for a PSU and 1 card
Reply to xon_8
in that case i would rather get a 5770 performs almost the same as a 4870 but has dx11 support for future compatibility
Reply to obsidian86
- 0 +
is dx11 that big a deal coz the 4890 looks like a better card....i looked up some more stuff and the 5850 looks like a sweet deal...i might save up for it....that would be a much better card than all the cards we have mentioned thus far right????
thing is what PSU would i need to run it??
Reply to xon_8
There are 1085 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
