Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Boot problem with Sapphire Vapor-X Radeon 4890 2gb.
Forum Graphic & Displays : Graphics Cards - Boot problem with Sapphire Vapor-X Radeon 4890 2gb.
Hey all,
I got sort of a problem with my new Radeon 4890 card. Got it today and when I try to boot the computer, the monitor just turns blank and the computer wont boot. All I get is "check signal cable". It runs perfectly fine when I chuck my old graphics card (GeForce 8500 GT) in and go with the same cables (VGA with a VGA to DVI-I adapter). What happens is that the new Radeon just goes to max fan speed, making a hell-of-a-lot of noise and then nothing. Lights on the Radeon 4890 are on and it seem to be working properly. I connected my power supply (Corsair TX650w) to the Radeon 4890, but the Radeon got 2 different slots (one 2x3 pins and one 2x4 pins) and as the power supply I have got some pins which says PCI-E on it, and matched the 2x3 slot I figured that was the way to go. Not sure if it's the right one though so please feel free to correct me.
Anyway, my spec is as follows;
Motherboard: Asus p5n-d
Memory: 2x2gb corsair ddr2 sdram
CPU: Intel Core 2 Quad Q9550
Monitor: Samsung SyncMaster 2032bw
PSU: Corsair tx650w
Old GPU: GeForce 8500 GT
New GPU: Radeon 4890 2gb
So I really don't know what the problem is. As I mentioned, I don't even get it to boot far enough to get to the bios. The GPU fan just goes nuts and nothing happens. I tried to problemshoot as much as I could. I removed 1 of my 2 RAM to no avail, also reset my bios to default (not done the clean sweep you do on the motherboard though, as I have no idea how to do it), checked with and without my VGA to DVI-I adapter, my HDMI to DVI-I adapter etc etc. I'm unsure if the cables are the problem though, as I'm running the CPU now with my old GPU with the VGA to DVI-I adapter and it works fine.
So please, if anybody had any similar problem, or any idea, please let me know. I'm sorry if my description of the problem is a bit messy, but if anything is unclear, just ask and I'll try to explain it in more transparent terms. Thanks.
Sponsored Links
Problem solved. I apparently had to connect both power connectors to the graphics card. Here I was thinking that there were 2 different so the user could choose which one to use.
Reply to Dashiva
There are 1301 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
