Hi everyone, I have been having an issue with my home built pc hopefully you guys can provide me some help, thanks in advance!
When I first built my system I put a 750 corsair psu in it. My pc was running fine until a few months and the system would restart. I looked at everything and finally took it to a shop and they swapped the psu to a 450 watt (startech). it has been running fine for about 6 mons until now.
My new problem is that when I turn my system off and turn back on immediatley it will turn on for 2 seconds then off back on then off. If I let my system sit for about 10 mins it boots up fine. It doesnt restart will I am using it but it is concerning for me.
Here are my specs:
case - Cooler Master Cosmos S
hd - WD Cavier 640 GB
hs - xigmatek 120mm Rifle
ram - OCZ platinum 4GB DDr2 1066
vc - Asus 4850
mb - Gigabyte GA x48 DS4
cpu - C2D e8500 wolfdale 3.16
psu - 450 watt startech
Please let me know if you have any ideas or advice to help me figure out what is going on with this PC. Thanks so much!!
Here are my specs:
vc - Asus 4850
