ok this might be a bit pathetic but i have no idea what thse settings might do ;\. so im asking for a little guidance lol
on my gts 250 it is supplied with vtune software which i am using to change these settings.
core clock speed is default 700mhz but can go upto 920 mhz
memory clock speed is default 900mhz but can go upto 1200 mhz
shader clock speed is default 1500 mhz but can go upto 1990 mhz
also there is a box to link the clocks should this be ticked?
my question is what is the best settings to have my clocks running at? should the speeds be maxed or kept as default? and should they be linked or unlinked?
thanks for any help u can give i just want the best from my card
