Custom Built Gaming PC Help
I have recently decided to build myself a computer as my laptop is outdated and can not handle 3d software applications and games that I wish to run.
This is the first computer I have ever built and i'm obviously trying to be cautious because of this. I have had a friend to help me and I have also tried to do a bit of research myself. To find all the parts I used ebuyer.
Please look at the parts below I have chosen and let me know your views and if it will definatley all run ok.
Thanks.
AMD Phenom II X4 940 3GHz Socket AM2+ 6MB L3 Cache Retail Boxed Processor
Asus M3N-HT Deluxe/Mempipe Nforce 780a SLI Socket AM2+ onboard VGA HDMI audio ATX Motherboard
Corsair 4GB (2x2GB) DDR2 800MHz/PC2-6400 XMS2 Memory Kit CL5 1.8v
Samsung HD103SJ Spinpoint F3 1TB Hard Drive SATAII 7200rpm 32MB Cache - OEM
ZOTAC GTX260 192 Core SYNERGY EDITION 896MB DDR3 Dual DVI PhysX and Cuda ready PCI-E Graphics Card
Black Mid Tower Gaming Case with Massive 14cm Front Fan - No PSU
Arctic Power 700W PSU - With PCI-E, 4x SATA, 20+4, ATX12V, 8pin +12V Connectors
6 answers Last reply
More about custom built gaming help
  1. it will run ok but its not the best you can get for your money
  2. Like he said
    It will work good for you but consider all other things within your budget
    Good luck
  3. Look fir i5 750
    RADEON 5770 HD
    What is it you would reccomend then? The main reason it may seem expensive is because of the monitor I have chosen. Given that all the parts are good quality i would assume that they would run very well. My budget is preferably between £500 - £600 but I will be willing to spend more if certain parts will benefit me in the future.
  5. http://www.tomshardware.co.uk/forum/261222-13-build-advice
    could you use this format please it helps us a lot
    Thank you for pointing me in the direction of this thread. I have filled it out and have posted it a new thread.
    http://www.tomshardware.co.uk/forum/277951-13-custom-built-gaming-computer-advice
    Thanks again for your help.
    I really apprieciate it. :D
Power Supplies Components
