Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > Update problem: cable blocking the HFS
Forum Homebuilt Systems : General Homebuilt - Update problem: cable blocking the HFS
Hi,
I have currently a e6400 on a P5B dlx. It was hard to instal the cpu w/ the stock heatsink on the board (2 years ago) b/c the cable from the PSU to the CPUs socket is too short. I totally forgot that when I decided to buy my updates parts.
I was wondering if it's possible to find any extension and where?
Sponsored Links
Excellent! but it's newegg.com =((.
Tried to find it on newegg.ca but it doesnt exist.
This cable is correct?
Athena Power 12" EPS-12V (8Pin) connector Extension Cable Model Cable-AD10 - OEM
I have this one too, a little cheaper with less description:
APEVIA 9.5" 4 Pin P4 /12V to 8 Pin P8 /12V Power Supply Converter Cable Model CVT48
I'll be checking on ncix and tigerdirect your cable...
Message edited by Just a nickname on 10-22-2009 at 12:01:22 AM
Reply to Just a nickname
If your motherboard has an 8-Pin connector, either the first or third ones will work just fine. You can choose which ones is best for you..
------------------------------ Recommended Builds by Usage
Step-by-Step Guide to Building a PC
Reply to tecmo34
First one of my first post and third one as my third post? just to be sure that you dont consider yours as the first one.
Yes... The first one in your reply post to mine and the post by its self... not my post :(
Reply to tecmo34
Oh my god. The shipping is 200% the price. Ewww... 10$ for a 5$ item. They should have a politic against these kind of rob. Bad USP... tsk tsk tsk
I was just confused b/c the third cable I posted is the same you posted... so basic logic: Third cable = First cable; Second cable = Athena; Third cable = APEVIA. I know I am crazy.
There are 1016 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
