Parts for building
So now i decided to rebuild my entire system
I looked around and i found these parts that im planning on to buy
Motherboard: Gigabyte 770TA-UD3 Motherboard
RAM: 4GB DDR3 1333 eCollegePC Memory found on ebay - http://cgi.ebay.com/4GB-DDR3-1333-eCollegePC-Memory-Upgrade_W0QQitemZ380171957650QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item588403b592
Processor: AMD Athlon II X2 240 - Ill upgrade 2 a new one when i got the money
PSU: OCZ OCZZ650 Z Series Power Supply - 650-Watt
I already got a great graphics card but will it work with these motherboard and processor?
PNY Verto GeForce 9600 GT
And my final question. I got a harddrive with Windows XP 32bit Installed on if i used that harddrive on my mother board will i get any problems at all? Cause i dont want to download and reinstall all my applications again
8 answers Last reply
More about parts building
  1. Btw i read wrong on the RAM xD but could anyone find a cheap 4gb ram on ebay or some kind of site?
  2. hi welcome to tom's :)
    can u state us ur overall budget... maybe we can help you better with choosing the parts.. the mobo seems a weak one in my opinion..
    Well all im looking for is RAM, Motherboard and Processor and i want a AM3 or AM2+
    budget around 350-400 dollars
  4. I got a hard drive with Windows XP 32bit Installed on my old motherboard, if i used that hard drive on my new mother board will i get any problems at all? Cause i don't want to download/reinstall all my applications again with a new operating system.
    Thanks a lot for the help BTW.
    -Venzin
  5. no problems you can take the plunge...
  6. Thanks you for all your help abhishekk89 your a great guy :D
  7. anytime :)
Motherboards Product
