I've been having problems with dial-up for a while (yes, yes, you can stop laughing now) with not being able to hold a decent connection for very long. Most of the time, the connection will "stop working", i.e., it will stop transmitting and receiving data. This has been a constant problem, but has been even more of a problem in the past year or so, because I have had to use a 15/20 ft phone extension cable to connect my modem to the wall jack.
The thing is, the wall jack was added some while ago by a technician, and runs along the outside of my house to the network interface box. Now, I believe that first of all, this outside cable contributes to some of the static because the other day during a lighting storm I picked up a phone which I plugged into that jack, and pressed a button, and listened to the silence. There was crackling and static. However, since that incident I haven't heard any static/crackling.
So, that would leave the long extension cable as some sort of interference-collecting element. Without having to move the computer close to the jack, what can I do? I've been looking a cable with uses CAT networking cable but is modified on the ends ot use RJ-11 jacks (http://www.staples.com/Catalog/Browse/SKU.asp?BCFlag=False&PageType=1&SKU=im1151537). Would this help in my situation if I replaced my current extension with the CAT connection?
Also, what can I do to reduce interference on the regular cable (the extension plugs into a surge suppresor, from which comes a regular phone cable and into the modem)? For example, is there something I could wrap it in to potentially reduce any interference?
Oh, and I do not believe it's an ISP problem because I have been through many ISP's and the problem still exists. Also, the modem is not at fault because a have a decent modem (a USR hardware modem 5610B) and I had the same problems (though more so) with my older winmodem.
<P ID="edit"><FONT SIZE=-1><EM>Edited by ashish34 on 06/27/04 05:59 PM.</EM></FONT></P>
If you're handy, instead of using regular twisted pair cable (phone cord), upgrade to CAT-5 or CAT-5E. Sure, it has more wires, but just choose four colors, crimp them at either end with RJ-11 connectors, and use that. Replace as much of the phone cord as you have access to. Ethernet cords are much more insulated than plain phone cords, so that should help noise throughout the home
