hey,
having problems overclocking my cpu... been reading about other people having problems doing the same thing, and from what it sounds like is a power issue that needs to be adjusted but im not sure what to do...
every time i try to overclock from the auto settings, even just a teeny bit, when it restarts my computer goes black. i have to do a hard restart to get it to boot back up, and says overclocking failed... restore defaults, da da da...
i have an fx 4100 with an asus mb m5a88-m, 16gb ddr3. any help would be appreciated, i am not super good with this type of thing, so try to not get too technical with me if u can :\
there are two ways that i can that i have noticed to overclock the cpu... one way is to adjust down a menu of clock speeds, ranging up to 6000 mhz... and the other way is to overclock by percentages - 2, 5, 8, 10 %... but that also overclocks the memory, which is fine if i have to, but i didnt really care about that. all i wanted to do was overclock the cpu, but if i can overclock the memory, that would be fine too, but like i said, not my first priority.
thanks,
any help would be appreciated.
thanks,
