Case-Fans for Corsair 600T @ ~30dB
Hi,
i've considered to exchange my stock case fans on my Corsair 600t white edition, since the front 200mm fan is making a whiny noise. i've been looking arround quite a bit for new fans, but can't seem to find some proper.
now i'm asking the community to help me find some nice quiet fans.
when i'm changing the front 200mm i would also like to change the top 200mm for maybe 2x120mm instead.
Have a nice day :)
5 answers Last reply
More about case fans corsair 600t 30db
  1. i just found out, that the preinstalled fans are 200x200x20mm. the 200mm fans you provide are 30mm thick. :/
    but the 120mm noctua fans would go great with my NH-14D. :D
    a quick look at newegg shows, that they do have 20mm thick 200mm fans. but they all mount as exhaust fans(why??).
    seems i need to get one of those and make some makeshift intake-fans of them..
  2. i've just remembered a new fan manufacturer and looked up their fans.
    Bitfenix spectre pro
    http://www.bitfenix.com/global/en/products/accessories/spectre-pro/
    http://www.amazon.co.uk/Bitfenix-Spectre-Non-LED-Black-BFF-SPRO-20025KK-RP/dp/B0067LYYI0/ref=sr_1_2?s=computers&ie=UTF8&qid=1329479606&sr=1-2
    an incredible 148.72 CFM!! but a bit on the loud side. 27,5 dB
    but this one is 25mm thick.. i need to find out if my case can fit those extra 5mm in the front.
    and this one
    Bitfenix spectre
    http://www.bitfenix.com/global/en/products/accessories/spectre-led#specs
    http://www.amazon.co.uk/Bitfenix-Spectre-Non-LED-Black-Quiet/dp/B004H1E4FU/ref=sr_1_5?s=computers&ie=UTF8&qid=1329479606&sr=1-5
    this one is exactly 20mm thick and would fit my case i think ^^
    but only has 47.4CFM but much quieter then the spectre pro. <20dB
  3. If you don't have buy an fan controller and with that you can controll the RPM of the fans.Those fans look good.
  4. Xigmatek XLF-F2004 200mm White led.800rpm=as you've found out the mounting needs to be modified for intake.
    http://www.amazon.co.uk/exec/obidos/ASIN/b003heqipw/geizhals07-21/ref=nosim?m=A3P5ROKL5A1OLE
    Enermax T.B. SILENCE FAN 120MM
    http://www.amazon.co.uk/gp/product/B003IB2HYA/ref=olp_product_details?ie=UTF8&me=&seller=
    Whatever you do don't buy a 200mm NZXT = proprietory mounting.
    I think you should go for one of the BitFenix 200mm = the PRO at 27.5db is quiet.
    Anything up to 30db is considered quiet.
    20db and under is silent.
Heatsinks Cases Corsair Overclocking Product
