Tom's Hardware > Forum > Homebuilt Systems > New System Build > Final system build 1000$ i5
Forum Homebuilt Systems : New System Build - Final system build 1000$ i5
I am now pretty confident I have found the ideal build for me.
APPROXIMATE PURCHASE DATE: Within a month
BUDGET RANGE: 1000 CHF = 1000$ Can be within 900 - 1100 though.
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: GAMING only
PARTS NOT REQUIRED: Mouse
PREFERRED WEBSITE(S) FOR PARTS: www.digitec.ch ( its from Switzerland but has a English translation. )
PARTS PREFERENCES: Non actually
OVERCLOCKING: I might after a year or so
SLI OR CROSSFIRE: Yes, when 5850's drop prices
MONITOR RESOLUTION: 1920x1080
ADDITIONAL COMMENTS: Would prefer a windowed case =)
These are links to the build. Same build different layout.
http://www.digitec.ch/?wk=c37WAuQg [...] oppinglist
http://www.digitec.ch/?wk=c37WAuQgDjs&view=product
Could you please comment the build and tell me if some things need changing.
Sponsored Links
I don't see any problems with that build, nice work!
------------------------------ How To Ask For Build Advice
Homebuilt PC Buying Guide
Reply to jbakerlent
- 0 +
Overall really good build for the money. My only concern with the LGA1156 CPU is the compatibility with the more "performance level" CPU in the future, the 6 cores i9 for example will only work on LGA1366 (I don't know the plan for any LGA1156 equivalent). If you don't mind much (nothing wrong with that BTW) then no problem, you will enjoy your build I have no doubts; if you would prefer to keep i9 as a possible upgrade in the future, I would do the following alterations:
The bulk of the price difference is actually the CPU which is a shame because it's not really better than the i5 750 by itself. If you could find some kind of deal to bring the 170$ gap down, it would probably be worth it more.
Reply to Zenthar
May I suggest these motherboards:
Gigabyte GA-P55-UD4, Intel P55, LGA1156, SLI, CFX
Asus P7P55D, Intel P55, LGA1156, SLI, CFX
Reply to evongugg
Second the Asus board, also if you plan to overclock down the line you might want to get 1600ddr3 memory.
Reply to cory1234
Thanks for the reply's.
About the 920, I'm not really to interested in that option. Mainly because of the too big price difference for no performance upgrade.
Hmm the motherboards. Could you tell me why I would have to spend more for the Gigabyte option?
And why the Asus for the same price? With less options ( from my newbie point of view ).
I have changed the memory to 1600 from the same brand and 8-8-8 timing. For just 5 CHF extra, thanks for the tip.
Please keep commenting, it keeps improving my system =).
Reply to greenpiggy
There are 943 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
  • 01:00 WookinPaNub won the Uniformed badge
  • 01:00 kwadams won the Uniformed badge
  • 21:57 brockh won the Sophmore badge
  • 01:00 xpax won the Freshman badge
