Hi. I wonder if I could ask for some advice. I want to put together a new build for my home office in the next week or so. I have some very specific requirements, and I'd like to know if anyone has advice or knows of any incompatibility I've not noticed!
Basically, it will be a very simple and cheap system, but needs to drive four monitors (properly, as in WDDM support for Vista/7). I'm not into games at all, so all-out performance isn't great, but it needs to be quicker than my existing dell 745 2.4ghz. It also needs to be VERY quiet. Here's the bits I've selected:
Motherboard - ASROCK SKT-AM2 ALIVEXFIRE-ESATA2 R3.0 S/L 2000MT/s
Rather than pricey quad-head graphics card, I figured a cheap SLI-capable board with 2 x PCex16 and a couple of cheap cards would be a better option...
http://www.ginger6.com/components-motherboards-asrock-sktam2-alivexfireesata2-2000mts-p-30312.html
CPU - AMD ATHLON II X2 250 AM3 3.0GHz
http://www.aria.co.uk/Products/Components/CPUs+/+Processors/AMD/Athlon+II+X2+AM3/AMD+ATHLON+II+X2+250+AM3+3.0GHz+?productId=37441
RAM - PatriotPC2-6400 C4 Viper Extreme Performance (2x2GB)
http://www.aria.co.uk/Products/Components/Memory/DDR2/DDR2+800+(PC6400)/Patriot+4GB+PC2-6400+C4+Viper+Extreme+Performance+(2x2GB)+?productId=29822
Power supply - rasurbo DLP 430W Quiet PSU 4GB (apparently cheap and very quiet)
Case - Lian Li PC-6289 (I think I've had one of these before. Simple alu case)
http://www.cclonline.com/product-info.asp?product_id=2761&category_id=237&manufacturer_id=0&tid=pc-6289
Graphics - 2 x Asus EN8400GS SILENT/HTP/512M/V2, PCI-E, 512MB DDR2 (seem perfect. Very cheap, crap for games(?) but will drive Vista/7 with aero. Also, fanless!)
http://www.aria.co.uk/Products/Components/Graphics+Cards/PCI-E/nVIDIA+GeForce+8+Series/Asus+EN8400GS+SILENT/HTP/512M/V2,+PCI-E,+512MB+DDR2.+?productId=37491&rqcType=new#rqc
Cooler - maybe the bundled retail one, but I was thinking of one of those massive heatpipe fanless ones, if I could get away with it. I'm not one of those people obsessed by cooling, if it runs warm but doesn't actually explode/catch fire, I'm happy
I don't need any storage or optical drives. What do you think - is this a sensible part choice? I can purchase of of this for around £250, so it's cheap as chips....!
