Tom's Hardware > Forum > Graphic & Displays > ATI > HDMI Problem with ATI Radeon 4200 (No Sound, 4:3)
Forum Graphic & Displays : ATI - HDMI Problem with ATI Radeon 4200 (No Sound, 4:3)
I will try to best describe the problems and the hardware that I have.
Just built a new system and I was trying to have it to where I can switch between both my computer monitor and my VIZIO HDTV so that I can watch my blue ray movies directly from my computer on my HDTV. However, I haven't had any luck at the moment.
ASUS - m4a785td-v evo has ATI RADEON 4200 with HDMI
AMD Athlon II X4 620 Propus 2.6GHz
I've hooked up the HDMI Cable to both ends and I get a picture on my TV but it does not fill out the entire screen, looks more like a standard 4:3 with the black bars on the side. Second issue is that no sound is coming of the HDMI cable. I've installed the HDMI Realtek Drivers still doesn't do anything. I have an option for both ATI HD AUDIO rear output and HD Audio Rear output, I've tried both and no sound on the Vizio TV, if I switch to the ATI HD Audio I no longer have sound coming out of my speakers, so I have to toggle back and forth to get sound, but still no sound coming out of the TV.
I also do not have an option in catalyst to enable HDMI as a display option I only have DVI (1), could this be the reason I can get a wide picture on the TV?
I almost forgot. When I try to install the drivers for the ATI HDMI Driver from the ASUS DVD it constantly tells me I have to install the audio driver first, even though I install it restart computer and still can not install the ATI HDMI DRiver off of the CD. So I went looking on the net for the driver installed it, and still nothing.
Here are a list of drivers that are currently installed:
ATI High Definition Audio Device: 5.0.50000.17
VIA High Definition Audio 6.0.1.7200
ATI Radeon 4200 8.661.0.0
I've installed and re-installed all the drivers, and tried to find a problem but still same outcome. As I am posting this message I just remember I just uninstalled the Newest Realtek High Definition Audio Driver 2.58 (5.10.0.5612). So it is currently not displayed in my Device manager.
Thanks for any and all helo
Sponsored Links
Are you using some sort of adapter, or another medium between the TV and the VC? There have been many problems like that, and no solution I am aware of.
------------------------------ "It could also be using the testicles of squirrels but until more is known it's all supposition and guess work, best to just sit back and wait."
-MouseMonkey
Reply to shadow187
Did you try downloading the latest drivers from AMD? I find it hard to believe Catalyst 8.6 is the latest version for the HD 4200 series. I'd guess it's 9.10 like the rest of them.
Reply to brockh
No not using any type of adapter!
@ BROCKh
Driver Packaging Version 8.661-090923a1-083739C-ATI
Catalystâ„¢ Version 09.10
Provider ATI Technologies Inc.
2D Driver Version 6.14.10.6973
2D Driver File Path System/CurrentControlSet/Control/Video/{6A8118FB-81D7-4224-9E5C-0050B3642B9D}/0000
Direct3D Version 6.14.10.0678
OpenGL Version 6.14.10.9026
Catalystâ„¢ Control Center Version 2009.0925.1707.28889
Reply to djartek
Hi,
I have a similar problem to you with an ASRock M3A785GXH/128M motherboard - I get a display which will not fill the whole screen (similar to what you describe as 4:3). I know the TV is OK, as my laptop which has onboard Nvidia 8200 fills the whole screen at 1920x1080. Not sure what the solution is at the moment (am trying other OSs to see if it is a driver problem). I am using Windows 7, and it works OK during installation which leads me to think it is a driver problem.
Cheers,
Dave Harrington
Reply to daveharruk
There are 565 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
