Okay so i have the Cooler Master Storm Sniper case and today i figured id do some cable managment for the new cold cathodes im getting. So after about and hour and half of zip tieing and velcoring cables to the back of the motherboard tray i figured it be time to put the side panel on. I started pushing it on and it was going good and all of a sudden it gettings stuck about half an inch from closing fully and i can use force and push it all the way on but then i need to use triple the force to pull it off so i checked if any cables were getting in the way and there seems to be nothing wrong with where the cables are located.
