Where is the system battery located on dell dimension 8300
after reading so many blogs on system low voltage battery on Dell Dimension 8300, I need to know where it is located...am not a computer geek. at all. Thanks for your help.
6 answers Last reply
More about where system battery located dell dimension 8300
  1. Just below the ram slots.
  2. That info is on the manual of the said system, under the section which tell you how to reset the BIOS/CMOS.
  3. http://www.redplanettrading.com/ebay/motherboards/m2035/topview800.jpg
    you can see it sitting in this pic of your motherboard.
    circle silver thing just like 1cm up and to the right of the little chip with Intel on it.
  4. Hmm, look at that, just below the ram slots.
  5. Indeed
  6. Thank you all for your help....the picture was a great help. Now I need to find out what type of battery and then change it.
    Again thank you. :pt1cable:
    Cheers.
CPUs Battery Dimension Dell
