I have spent about 6 hours scoring the web for info on how to interpret Spinrite6 S.M.A.R.T. results. I hope someone who has experience using the program can help me. I am testing a 100GB ide drive. It is at 30% complete and has the following SMART readings.
temp 111F (what should normal temp be?)
ECC CORRECTED - err count 1389249/ minimum 7061/ err rate 11761/maximum 18487
SEEK ERRORS - err count 32510 / minimum 149/err rate 275/ maximum 488
WRITE ERRORS - err count 310294 /minimum 2397/err rate 2593 / maximum 3236
On the Graphic Status Display no sectors indicate any defective, recovered, or unrecovered data. All of the tested sectors are marked in white.
I can not figure out what this all means and what readings are acceptable or what clearly indicates a hard drive failure. Everything on all of Spinrite's screens is in white. Nothing is in red. I downloaded the Spinrite5 documentation but it was no help. I hope someone can help me and that I have not wasted $70 on this program. From all my research I have found a lot of other people are just as confused as I am by Spinrite readings. You would think that there would be explanatory info somewhere that novices like me can understand. I appreciate any help. Thank you.
