Tom's Hardware > Forum > Homebuilt Systems > New System Build > Looking for an external power supply for mini itx, HTPC External Power
Forum Homebuilt Systems : New System Build - Looking for an external power supply for mini itx, HTPC External Power
Im trying to find ( and failing epicly ) an external power supply unit for my htpc build, my build specifications are listed below. I do not have my motherboard or tv tunner yet as the motherboard will be released in Mid November. I need to find an external psu something like the picture posted which is a PicoPSU-150-XT ( which is a 150 watt psu ) but I want to make sure that 150 will be enough for my application, All the 200 watt internal connectors are too big for my case so if I need more than 150 watt I will have to get an internal psu. UNLESS someone knows of some that looks like the picture only in a 200 watt. Really I even wonder if I could just get away with using the picopsu-150 watt power adater, as I have no clue as to what the wattage usages are between my components or how many watts an atom n330 motherboard even uses.
ANY HELP WILL BE GREATLY APPRECIATED !
Operating System - WINDOWS 7 Ultimate
Case - Lian Li PC-Q07 Mini-ITX Case
HDD - Western Digital WD500AAKS ( 500GB x 1 )
Ram - Corsair 800mhz CM2X1024-6400C4 ( 2GB x 2 )
Optical Drive - 5.25 Full Size HD-DVD / BLU-RAY Drive ( Sata connected )
TV Tunner - Hauppauge WinTV-HVR-2250 Dual TV Tuner ( PCI-Express x1 )
Motherboard - ZOTAC IONITX-G-E ( 1.6 GHZ Dual Core Atom N330 )
Motherboard specs can be found at the link below :
http://www.zotacusa.com/zotac-ioni [...] board.html
PicoPSU specs can be found at the following link :
http://www.mini-box.com/picoPSU-15 [...] 8Ta38Qahf0
There is an internal psu extender mount available for my case at the link below:
http://www.lian-li.com/v2/en/produ [...] dex=84&g=f
Sponsored Links
Actually theres a problem with your build. The Zotac Ion boards do not come with a true pci-x slot. Its actually a mini pci-x slot for a network card. Most zotac HTPC builds need to use a USB type tuner or a network based on like the Homerun and Hava. You can actually get the zotac board with an external 90w PS which is plenty for what your looking for here
http://www.newegg.com/Product/Prod [...] _-Product. You can get a PCI slot with the ASUS ion board though which is also available http://www.newegg.com/Product/Prod [...] _-Product. A 150 watt power supply is plenty for this setup also.
Reply to jdavis1979
That would be true if you didnt look at the board inforfmation at the link i posted, the board I choose has BOTH, a mini pci meant for wifi, AND a regular PCI-E x 1
Message edited by cumberledgej on 10-26-2009 at 07:58:08 AM
Reply to cumberledgej
Well your link was bad....and I missed it when i searched for it so was wrong there. Either way 150 watts should be more than enough.
Reply to jdavis1979
There are 905 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
