Hello, I am new(ish) to water cooling and want to build a fully fledged system around it. I have no main prefence to price other than not too expensive. I am going to order the NZXT Switch 810 case and the Sabertooth p67 motherboard within a few months, and would like to have decided on a efficient and stylish solution for liquid cooling. So far I have learnt about compression fittings, radiators, pumps and the like, and would certainly like the system to contain compression fittings. I will eventually buy 2 GTX 680 hydro's (if they exist in the future) for SLI. I will be able to get one triple and one double radiator to fit without modding, will it be enough ? I will also do some overclocking, 4GHz or 4.5GHz hopefully.
Current spec (off the top of my head, some figures may be out)
I5 2500k
XFX 850w 80+ silver
GTX 560
Asus P67 something (budget ran out)
Cheap case (budget ran out)
I5 2500k
XFX 850w 80+ silver
GTX 560
